Porsche PCM Upgrade/Hack for Android Auto? Is this real?
Old 03-07-2020, 08:09 PM
  #151
asellus
asellus's Avatar
Received 2,068 Likes on 1,284 Posts
So the only two points of concern I have are the MIBRoot patching and the adaptation coding stuff -- I only have an OBDeleven, no VCDS.
Does anyone have any insight on patching out the FEC checks? I've got the mibroot decompiled in Ghidra but am at a loss on where the checks would be located, either to update the checksum or remove it altogether.
Old 03-08-2020, 07:19 AM
  #152
stevilangel
4th Gear
stevilangel's Avatar
Default Help
I finally managed to decompress the ifs file but I dont find Mibroot in the folder. Asellus you can upload your ifs file so that I can do another test PLZ
Old 03-08-2020, 11:21 AM
  #153
asellus
asellus's Avatar
If you have decompressed the file, the directory created should haev some directories in it. You need to go into usr, then apps, then MIBRoot should be there.
Old 03-08-2020, 11:37 AM
  #154
JMark2
3rd Gear
JMark2's Avatar
I have the same issue. I used dumpifs as decribed with dumpifs_helper.sh but there are lots of files but no MIBRoot file.
It looks like the MIBRoot file is not in the ifs-root file of the update sd card. But I heard that it is there when the .bin file is copied directly from the car.
Can anyone clarify?
By the way, for anyone who gets empty folders, use a absolute path for dumpifs_helper.sh because it does not work with relative paths.
Old 03-08-2020, 04:36 PM
  #155
MIB2
4th Gear
MIB2's Avatar
Make an dump of IFS Filesystem on MIB System directly with following command:
mount -uw /net/mmx/fs/sda0/
cat /dev/fs0> /net/mmx/fs/sda0/ifsorig.bin
https://rennlist.com/forums/991/1049...l#post16022781 > Use Step 4.
On Original ifs-root.ifs from Firmware Update don't decompress all files (2 Images in ifs-root.ifs)!
Cut and paste this block of data from dumped ifs file into a new file (Step 4)
With the new ifs file (from dumped ifs image) you can decompress the files include MIBRoot.
Example for Ubuntu:
First steps:
sudo apt update
sudo apt install liblzo2-2
sudo apt install liblzo2-dev
sudo apt-get install libucl1 libucl-dev liblzo2-2 liblzo2-dev
cd dumpifs-master
make dumpifs
sudo cp ./dumpifs /usr/bin/dumpifs
sudo chmod 755 /usr/bin/dumpifs
sudo chmod 755 /mnt/c/a/dumpifs-master/dumpifs_helper.sh
./dumpifs_helper.sh /mnt/c/a/dumpifs-master/new.ifs
Richard Tozer (05-31-2020)
Old 03-08-2020, 04:40 PM
  #156
MIB2
4th Gear
MIB2's Avatar
Repack of extracted IFS Files:
Example for Ubuntu:
export QNX_TARGET="/"
cd /mnt/c/a/dumpifs-master
./mkxfs -t ifs -nn -o ./ -r / ./mkifs_attributes.txt ./ifs_extracted ./patched_ifs.ifs
Old 03-08-2020, 04:56 PM
  #157
MIB2
4th Gear
MIB2's Avatar
Flash procedure:
flashunlock
f l a s h i t -a ba0000 -d -v -f patched_ifs.ifs
flashlock
/usr/apps/mib2_ioc_flash reboot
(command for System will automaticaly reboot)
The following 2 users liked this post by MIB2:
Richard Tozer (05-31-2020), stevilangel (03-08-2020)
Old 03-08-2020, 07:07 PM
  #158
stevilangel
4th Gear
Originally Posted by MIB2
Flash procedure:
flashunlock
flashlock
Great illustration but I need to understand something, do we manually patch Mibroot or the command ./mkxfs does it automatically
Old 03-08-2020, 07:30 PM
  #159
MIB2
4th Gear
MIB2's Avatar
MIBRoot must be patched manually!
mkxfs is for repacking of the filesystem after patching the MIBRoot.
Old 03-08-2020, 07:36 PM
  #160
stevilangel
4th Gear
Can you explain more
Im not master with "Ghidra"
Old 03-09-2020, 12:30 AM
  #161
asellus
asellus's Avatar
How does one patch MIBRoot? I have it decompiled but I'm not seeing any obvious function names regarding FEC signature checks and the like.
Old 03-22-2020, 07:32 PM
  #162
Red-100
Red-100's Avatar
Great Work Chris!!
Old 03-30-2020, 12:13 PM
  #163
katita
3rd Gear
katita's Avatar
i use dumpifs and could extract mibroot for patching,but i not get files in correct folders, all files are in same folder.
could anyone help?
Old 04-19-2020, 02:33 PM
  #164
OWLY
OWLY's Avatar
Is there an easier way?
Old 04-24-2020, 09:24 AM
  #165
coiae
8th Gear
coiae's Avatar
Wink PCM4 UART Connection
1st Thanks to Chris2 for this amazing guide. 2nd I try USB-Ethernet connection and works fine... Now I need the pass for MHI2_ER_POG11_P4172 MU:1119.
I try with oaIQOqkW but no way, I read about install the toolbox from SD-CARD for obtain pass but I think I need the firmware to return the PCM to original state.
Please help me
Quick Reply: Porsche PCM Upgrade/Hack for Android Auto? Is this real?
