Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#4201
Yes - so it seems. But it does not require a degree in electronic engineering, computer programming, and nuclear physics as most of the people on this thread seem to have in order to get the replacement head units to work properly. I am blown away with the high level of skill and talent most here have. These units do not seem for those with faint of heart! I do have the Mr12Volt unit and I am quite happy with it and the installation was not so bad at all.
#4202
I personally hated how stupid the PCM is, so once I realized there are such option, I went with it. No more stupid Radio screaming at me every time I turn on the PCM after I left it in BT mode the last time. The PCM is such a joke.
#4203
Hey guys, following the discussion with @bmxtreme a few days ago, I just had a very successful 30 minutes! I managed to enable the secondary bluetooth chip on the Chstek and pair it with my throttle pedal controller app so I can control the throttle settings natively on the HU, rather than having to use my phone.
This should(!) work for other devices that do not pair to the default primary bluetooth chip. I will add the following to the next version of the guide:
ro.lsec.btname=Bluetooth 2
You should now be able to pair your other devices to Bluetooth 2. Here is my RaceChip throttle controller app running in full native mode, having paired the controller box to the Chstek:
I dont use CarPlay or AndroidAuto and have always used the Chstek in full native mode, so I'm always pleased when I can get something else working as a native app!
- Follow the instructions in the guide in the "Setting the boot animation" section to create a backup and copy the 4 files somewhere safe (PC, laptop etc)
- Create a copy of config.txt and call it something like config_orig.txt
- Edit config.txt and add the following 2 lines
- It doesn't really matter where they go as long as they are in between the rows starting with #. It should look something like this:
- Then copy the modified config.txt file and the file from your backup called lsec6315update to a blank FAT 32 formatted USB stick - you should only have these 2 files on the USB stick.
- Put the USB stick into the HU (original socket recommended) and the flash process should start and the HU will reboot when finished
- You should see a new option in Settings >Device >System Bluetooth Settings which gives you this:
#4204
So cool . . .
Assume it would work if you have smart garage door opener
#4205
bmxtreme (Today)
#4207
The add-on boards are not cheaper than the Android units, are considerably more difficult to install, and retain the outdated screen and processor of the PCM. The one benefit they have is that the appearance of the car remains entirely as original, and for some I acknowledge that this is an important factor. But for those who want a more modern unit, with a vastly superior screen, the Android units have much to commend them.
* I do realise that you were being humorous of course
#4208
Interesting discovery here, well situation i guess...
I had an iPhone 14 Pro that uses lightning connection. I was using an OEM cable to use wired carplay. However, with lightning it was a 60% success rate. Sometimes i would have to reboot the device for it to actually "authenticate" and use car play.
I got the new iPhone 16 pro, which switched to USB-C, and ordered an ANKER 6ft cable to route out behind the glove box, through the center console, and out the arm rest. It has a 100% connection rate. Not sure why, its probably just USB-C superiority (yes.. i know android folk have had it since the dawn of time)
Either way, Stoked
Either way, Stoked
ZedZed (Yesterday)
#4210
So I spoke to another user with my same car, 2014 Boxter S with Bose and he has the Erisin unit. He is sure that all speakers in the car produce sound. If I am reading correctly, users with the CHSTEK unit report not having sound in the rear speakers. Can anyone check me to make sure I am understanding correctly that the CHSTEK unit does not provide sound from the rear speakers?
TIA,
Brad
TIA,
Brad
#4211
TIA,
Brad
TIA,
Brad
Also here is the decoder for Erisin and looks like it's the same as what we get from CHSTEK, but in blue?
https://a.aliexpress.com/_msAyd4M
#4212
@bmxtreme do you you leave your battery monitor permanently connected? Wasn't sure on the current draw with the engine off.
I just ordered one... Another app to connect to the Chstek!
#4213
Either way, Stoked
Either way, Stoked
#4214
So with my lightning specifically, it would "authenticate" then fail. Its possible but any cord i tried, along with cleaning the port on my phone would give the same result.
#4215
