Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#4171
@ZedZed , thanks for your answers! I’ve now read through the manual in @andy2111 ’s signature—appreciate you pointing that out. It seems like I’m at a similar crossroads as you once were, deciding between PCM modification and other options. I’m not too concerned about the minor surgery on the PCM, as I’ve done that kind of work plenty of times. Sounds like we have similar IT backgrounds—I’ve got a box full of old PC, laptop, and phone parts too!
Since price isn’t a major concern, I think I’ll go ahead and pick up a Chstek to see how it works out. It seems like an easier and more cost-effective route to try first.
Thank you agin,
Hank
Thank you agin,
Hank
ZedZed (09-23-2024)
#4172
Love those wheels!!
I dont have Sport Chrono, but I noticed at the weekend that my head unit clock and the clock in the MFD were out by a couple of minutes. I have not seen that before and I had always assumed that the two used the same "time source", but maybe not - and this would mean that you do not have an issue with your sport chrono if this is the case. Does anyone else have an observation on this from their cars? I guess an easy test is to change the time on one display to see if it replicates on the other.
For the bright lights did you apply the "can_app.bin" fix? If you did then I think you need to pull the fuse to make the HU do a full power up from cold - I had to do this on mine to get the fix to work.
#4173
Super happy with the CHSTEK unit. I have three issues with it, which may or may not be because of the swap.
One: Discussed earlier in the thread about the small Sport Chrono clock not matching the digital clock. My dealer is ordering a new Sport Chrono gauge to see if that's the issue.
Three: I swapped out wheels and tires this last weekend and the TPMS will not reset and accept the new wheels. I'm assuming its bad TPMS sensors as the wheels sat for 3 years unused and I have new sensors coming this week. However, the thought crossed my mind that the PCM may be involved in the reset procedure and without it, it won't work. Its just a guess. If anyone has replaced wheels with the CHSTEK unit installed and got the sensors to update, please comment.
You may decide that the OEM TPMS is an expensive waste of money, and just install the in-wheel TPMS sensors and USB control box made by Erisin. This will save you a ton of money (no need for PIWIS coding) and also, IMO, the display and functionality of the Erisin TPMS sensors is superior to the OEM Porsche version. Andy @andy2111 (and my wife in her Cayman) run the Erisin TPMS, albeit with the external sensors mounted on the tyre valves, and both of us hold them in high regard. When the time comes to change the tyres on the Cayman, I will be installing the in-wheel Erisin sensors. They work exactly the same way but are obviously a more elegant solution than the external sensors.
Caveat - the info regarding the chrono clock is my experience on my former Panamera, and YMMV on a 911, Cayman, or any other model of Porsche.
Very nice too. Love the color of the car as well.
[/QUOTE]
#4174
@mac_flyer9
Is your chrono clock the version with the small analog clock inset into the dial (as opposed to a digital clock)? If so, it is possible that the hands have 'slipped' - they are notorious for actually falling off.
Andy's suggestion is a good one.- go into the MFD and set the time to a random time. The chrono clock should mimic this. If it approximates it, is the difference the same as it was when the dash time was correct? I mean, if it was 2 minutes different before, is it still 2 minutes different now, or something else entirely?
#4175
@mac_flyer9
I'm pretty sure its a bad Sport Chrono clock and dead TPMS sensors, as the previous set of wheels/tires read just fine on the MFD.
Thanks for all the information/advice/troubleshooting ideas as they are concise and helpful.
#4176
The clock has the digital time and small clock underneath it. It displays a different time every time I either program it or I turn on the GPS time and don't think the hands have slipped.
ZedZed (09-24-2024)
#4178
There should be another document in the same location which was written largely for the Erisin. It has not been updated in a while but a few of us here can try to help with any questions
#4179
Really happy with this upgrade. Handles my ThinkDiag, Viofo, HighwayRadar w/ R4 apps nicely. Only remaining thing is to try to figure how to remove those silence hissing sound when something is downloading or when moving my fingers around the screen. Hope the ferrite magnets will help.
#4180
How did you get the CHSTEK unit to connect to your R4? I use an R4 with Highway Radar as well. My primary hangup on going with one of these head units is that it seemed unlikely to allow for secondary (non-phone) bluetooth connections. Did you have any issues like that?
sys.fyt.bluetooth_type=1
lsec6315update
config.txt
Plug it into the USB port and flash away. You can then see a new setting in the "Device" menu call "System Bluetooth" when you press the "All" button.
More info here:
https://xdaforums.com/t/general-fyt-...mware.4396339/
Just be careful trying to do anything that was said in that forum, alot of them are garbage untested or outdated info which may or may not work. Proceed with caution.
Since it's annoying to keep my phone plugged in for USB tethering, I've since just use my phone with highway radar in the background - voice notification sounds fine with AndroidAuto. I used Macrodroid/Tasker to start it when its connected.
bigkraig (09-25-2024)
#4181
Yeah, out of box the secondary BT is disabled. There are 2 BT chips and you'll need to enable it by flashing the config file. Once enabled, I seem to be able to connect anything to it. First you need to extract your config file (this can be done using the backup process in the manual). And then just add this line to the config.txt file:
To flash the config file, your USB should just contains these files:
lsec6315update
config.txt
Plug it into the USB port and flash away. You can then see a new setting in the System menu when you press the "All" button.
More info here:
lsec6315update
config.txt
More info here:
Question: Why USB tethering vs using your phone's wifi hotspot? I use an app called "Auto Hotspot" that will automatically enable the hotspot based on a trigger. As soon as my phone connects to the car via bluetooth, the hotspot enables. Once that bluetooth connection is dropped, it turns off the hotspot. Worth trying if you want to use the head unit in native mode and don't want to deal with plugging in your phone. You could probably do the same with macrodriod or tasker.
#4182
Great info, thanks!
If you don't use AA/CP, then mobile hotspot is ideal, and this would be your perfect setup.
Natural1 (09-25-2024)
#4183
They are very similar so most of what applies to the CHSTEK will apply to the Erisin too, especially with regard to installation etc. As Andy points out, we started the Guide with the Erisin, and then most guys switched over to the CHSTEK, mainly for aesthetic reasons, eg a bigger screen and physical buttons. The early Guide for the Erisin is in the download folder linked in Andy's sig.
I am one of the few running an Erisin still (in my wife's Cayman) so if you have any specific Erisin questions I am happy to do my best to help.
#4184
lsec6315update
config.txt
More info here:
lsec6315update
config.txt
More info here:
There is more info here where a guy got some help getting it working in his Macan: Question - Android Newb Identifying board type and looking to B/U (DAINAV unit) | XDA Forums
Also note there are some settings mentioned to adjust the mic and BT speaker which may interest some of the people who have wanted to adjust these
persist.audio.mic.senstivity=3
persist.btmic.gain=9
persist.btspk.gain=7
Anyway, back to setting up the secondary Bluetooth connection - here is the config I am going to try, based on the post I linked to above:
I added the items in yellow.
My 'sys.fyt.bluetooth_type=' originally had nothing at the end, so I just added the 1
@bmxtreme did you add the last 3 lines? The explanation is in the post above.
I'll try this at the weekend and report back.
#4185
I have been meaning to try this for ages so I can run my throttle pedal Android app direct on the HU instead of on my phone.
The mic settings - I didn't try since there are reports where it made it sound like crap, so if no problem, don't fix it
andy2111 (09-25-2024)
