Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#1666
I did the Isudar install and had issues with Entry & Drive and can only attribute it to the installation of the Isudar board as it went away after I pulled it. There were times I needed to use the physical key to unlock the car and then still would have trouble staring, getting the message "Key fob not found", so I'd have to resort to pulling the dummy key and insert the actual fob to start the car. I also had issues with the board hijacking my wifi LAN while at home after parking in the garage. Additionally I continually had problems with sound not being present, which was probably due to some setting in the PCM that would reset, but this was just another annoyance because of the Isudar board.
I installed one of the Android head units and so far it's like a blessing from heaven. The Entry & Drive issues that were troublesome, all went away. I couldn't be more pleased to have an updated system running wireless CarPlay natively and have a screen that looks much better and responds more quickly.
The following 2 users liked this post by Live Steam:
CarreraFahrer (06-23-2024),
ZedZed (12-03-2023)
#1667
Was it some time ago that you had the bad experiences with Android HUs? Or maybe they were 2Gb (RAM) quad core units, which aren't really up to the task of running modern Android? I think they have come a long way in the past couple of years, with terrific octacore processors and plenty of RAM available. There's a lot of us running these HUs now, without any operational issues once they have been installed right and set up right. Might be worth revisiting?
Chuck245 (12-03-2023)
#1668
Did you get the blank screen before you installed the Isudar? If not, then check all the Isudar settings for some way to enable or disable the camera.
ZedZed (12-03-2023)
#1670
I don't know how a Pioneer with a decent install bezel looks more aftermarket than that Android thing, but taste is certainly subjective.
#1671
It's been a while since I had a working PCM here, so I could be wrong, but can you switch off the backup camera in the PCM's settings? I recall some settings where you could enable the guide lines, turn off camera etc. Might be worth a look.
#1672
#1673
I would email Isudar support and ask them. cherie@isudar.com and kimi@isudar.com. They should be able to help you.
#1674
Anyone know which wire triggers the camera to go on when shifting into reverse? This is for the Chinese HU. I can manually switch the camera on via a button in the sub-menu of the main UI. However it doesn't trigger automatically when shifting into reverse.
#1675
I could be wrong. But isn't the Aftermarket/ Original backup camera switch, labeled poorly? Its not really an on/off switch. Slide left = aftermarket, slide right = original. Since you don't have an aftermarket, you need to select original ( slide right). It might be worth trying instead of searching for the discussion on that switch.
#1676
I've had three. One a unit I bought to put into a GMC Acadia, and two for friends. All of them were 2+ years ago. None of them worked well. Lot of features, but poorly executed. Buggy, terrible FM tuners mostly, but just poor integration with the car in general. Extra speakers to emulate car chimes. Extra mics that never worked well. Terrible backup camera functionality. Unstable, rebooting crap. All three of them.
#1677
Oddly enough, the screen tearing was NOT happening when I was in the garage playing with the backup camera setting. So I'm becoming more convinced this is a board issue, either hardware or firmware, and not a connection issue.
#1678
It's just the Pioneer logo on it that gives it away for me. One of the things I like about our units is that they have no visible branding (just like the OEM PCM). Other than that, that is a neat installation in the pic you linked to. And there is no doubt that a major brand like Pioneer is probably a better bet than an unknown Chinese brand. But then, the price reflects that too. And the lack of customisation would worry me - the ones I have seen have had fairly horrible interfaces, with no way of changing them. On the Android units, you can use any launcher you want. Then again, if you use Carplay or AA (like me) most of the time, the HU's GUI isn't all that relevant. I think we could both make pretty good cases either way. Most importantly, we agree that the old-fashioned PCM definitely needs to go, in favour of a more up-to-date unit.
The big issue for me is losing steering wheel buttons with an aftermarket radio. Nobody seems to make an adapter that supports Porsche in that world, or at least, I couldn't find it. Another plus would be HD radio - my PCM doesn't have it.
Does the Android radio add HD radio support? That would be a cool feature to have actually. I'd have to balance that vs my innate dubiousness of Android HUs and the loss of the other Porsche integrated features (that I never use, TBH).
#1679
There's a menu option on the Chinese HU for learning steering wheel buttons. Has this been discussed? My 911 does not have SW controls, so I can't test it. My Boxster does, but it also has a PCM 4.1. So that doesn't help either.
#1680
Which OEM features do you have in mind when you say you would lose some of the integrated features? Obviously, you would lose anything which is exclusive to the PCM itself, since that will have been discarded and replaced by the new HU - so that would be phone, satellite navigation and the original radio. All three of those will be replaced by the HU. I can't think of any other integrated features that I have lost.
Here is the first sat radio adapter that came up on my search - there are loads of them, and many much cheaper than this. In the UK we have 'DAB' radio (Digital Audio Broadcast) - in the US I believe this is called Sirius or something like that? Your local Amazon should have the correct adapter I would expect.
This is the kind of antenna adapter you would need to make the installation totally invisible:
I don't think any of the HUs have satellite radio built in because the frequency bands vary from country to country.
