Sponsored by: Road Spy
Consensus on stock exhaust and, who is considering getting an AM system?
Old 08-14-2014, 08:48 AM
  #211
Bob Rouleau
Still plays with cars.
Bob Rouleau's Avatar
Speed - sorry I am not going to do the search for you. As to loud exhausts, have you driven a Ferrari recently? My 430 was freaking loud - nice sound mind you but guaranteed to attract attention - perhaps what Ferrari wanted. I sold it because my GT3 was a superior car all around and much lower profile.
As I recall the GT3 RMS issue had PCNA claiming the aftermarket exhaust affected back pressure which - they claimed - caused the RMS leak. True or not? As to getting an engineering report, yeah sure. How much would that cost? PCNA holds all the technical cards in such a case.
Litigation in the USA is horribly expensive and taking on PCNA will cost far more than even an EP system and losing is always a possibility.
Old 08-14-2014, 09:54 AM
  #212
TT Surgeon
TT Surgeon's Avatar
True^^, remember PCNA decides the warranty position, not the dealer. The dealer can say whatever he wants, but on high ticket warranty work in the US and Canada, PCNA makes the call, regardless of dealer input. It doesnt matter how nice your exhaust looks, if you blow your motor PCNA will blame the exhaust 100% of the time. The chances of that happening are remote, but not zero. Nothing pro or con EP, just the facts, you have to decide for yourself whether it's worth it or not. On a 997.1tt with the anemic factory exhaust, yes it's clearly beneficial. Not so sure on the 991tts with the new DFI engine, Siemens ECU and 200k sticker. After the gt3 engine fiasco in the 991, I'm sure porsche is going to be very protective of the DFI engine in it's OEM form and highly likely to "blame mods" for any issues.
Alex has a good point re the cats, changing the muffler is one thing, but changing the cats is quiet another in the eyes of PCNA I'm afraid. One would probably be more likely to get away with it if the factory restrictive cats are left in place I suppose, but still rolling bthe dice even with the SW pipes. JMO
Old 08-14-2014, 10:02 AM
  #213
NVRANUF
NVRANUF's Avatar
Originally Posted by speed21
As you say, common sense generally prevails at one point. A manufacturer's warranty can not exclude or deny a customer's statutory or legal rights, and where it can be conclusively proven the component has had no involvement in the problem, warranty has to be acknowledged at one point.
Now on the other hand, when an AM product clearly has the potential to create warranty related issues (such as that system shown in the clip with all that nasty gunshot going on) or, has had an obvious involvement in an engine component failure, then it would be a very hard case for any end user to contest. Can you just imagine bringing in your TTS with a blown turbo, damaged Turbo seal or compressor wheel, burned or damaged valves etc with an exhaust fitted like that one shown on the you tube clip? You would be laughed out of the place.....and rightfully so.
As Alex points out these cars are becoming increasingly more complex and reliant upon the ancillary equipment to be functioning in accordance with the manufacturers requirements. Any exhaust system or pipe that creates nasty gunshot or, uses a cat converter (regardless of brand) which clearly sits outside of the OEM's core design principles has the potential to create engine complications. And then it becomes the end users problem to prove when things inevitably go wrong.
Agree totally Alex and do you blame them? I mean when you read the hyped up marketing crap surrounding some of the junk getting bolted onto these cars you have to seriously question the logic behind these initiatives especially when you look at the restrictive X junction box components some (don't need to name names) are using in a bid to lower production costs and max out profits. The omission of cat insulation shielding is just another example again.... No wonder so many of these AM cats fail prematurely. One only needs to observe the location of the cats on the engine/car and the high susceptibility to thermal shock related issues alone.
Re your new pipe Alex from what I can see and hear it has no gunshot issues at all and does not interfere with the emission systems in any adverse way. It looks like a nice job as usual. Top quality steel and manufacture, all made in USA... I can't see any dealer being able to get any traction in declining an engine related warranty problem using that.
Maybe time for gunner to get of the fence
Maybe I already did!
Originally Posted by Bob Rouleau
Just a word about the "gunshot"comments. Some people actually want an exhaust system which is as loud (nearly) as a race car. It makes sense for manufacturers to cater to those who want one. Probably the same people who ride very loud Harleys
From what I have seen up here and documented on Rennlist threads in the past, PCNA has denied warranty for cars with aftermarket exhausts. I recall a thread about a failed engine denied warranty coverage because of an aftermarket exhaust. On GT3's with leaky rear main seals, owners have been denied coverage because of aftermarket exhaust systems - also posted on Rennlist.
Dealers may be happy to install, on the other hand repairs over a certain amount require the approval of the PCNA tech rep who is NOT sympathetic to non OEM parts.
As to the legality, fighting PCNA in court is too costly for most to contemplate.
Regards,
Perhaps I was just an exception, but my dealer "up here" never denied my GT3 RMS repairs under warrant despite the Shark Werks by-pass exhaust I had installed.
I still content not all dealers are created equal and that some are better equipped at dispensing common sense than others...
Old 08-15-2014, 09:04 PM
  #214
speed21
speed21's Avatar
No problem - thought you had the info/threads at hand. Ferrari is in my family but not my scene. I would also take your GT3 RS any day of the week for the same reasons you have stated (and nice looking car you have there too btw). Report costs can vary, but on say a major failure max @ 1k with photos etc. Others can be a hundred or two or so....all depends on how much detail is required to get it over the line. PCNA can only hold cards to a point where the evidence allows them to. Leaky rear main seal and a claim declined over an exhaust?...well someone rolled over easily. As I said, I'm sure there is more to those stories.
Originally Posted by 1Gunner
[/B]
1) Then please tell gunner.
2) I'm sure your dealer looked at the rear seal issue and the SW exhaust and decided why be an *** when there is no need least of all justification to be.
Old 08-16-2014, 09:26 AM
  #215
NVRANUF
NVRANUF's Avatar
  1. Acme Corp, chief engineer Wile E. Coyote, using top grade mystery metal and of course... made in China!!
  2. Agreed, it just makes sense. But as previous folks commented, maybe the waters have changed. Time will tell!
Old 08-16-2014, 11:25 AM
  #216
kev_song
kev_song's Avatar
I finally got around to recording some video (Go Pro mounted to bumper) of the Sharkwerks Exhaust installed on my 991 Turbo S Cab. I was driving around in normal street traffic. I took 6 all together, with no sport/sport/sport+. The I did another with the Go Pro secured to the clamshell. Here are the ones of the camera mounted on the bumper near the exhaust tip. I did not use the paddle shifters for regular or sport.
Sport On
Sport +
Old 08-16-2014, 02:01 PM
  #217
NVRANUF
NVRANUF's Avatar
Cool!
But this sounds like a 3 cylinder engine at low rpm....
Any video with camera mounted in the center between the tail pipes?
With unconnected X-pipes it literally is a 3 cylinder engine at each tail pipe!
Old 08-16-2014, 09:45 PM
  #218
speed21
speed21's Avatar
[LIST=1][*]Acme Corp, chief engineer Wile E. Coyote, using top grade mystery metal and of course... made in China!!
So you bought the FS JWS (aka the "John Wayne Special") or, the one with the cats? It's ok you can tell us....no need for secrets here gunner.
owch!!! Something isn't right there Kev! It sounds truly awful, like an old diesel truck. I would recommend an immediate re take! Also add some decent RPMs and WOT too if you don't mind.
Old 08-16-2014, 09:50 PM
  #219
kev_song
kev_song's Avatar
So you bought the FS JWS (aka the "John Wayne Special") or, the one with the cats? It's ok you can tell us....no need for secrets here gunner. ' owch!!! Something isn't right there Kev! It sounds truly awful, like an old diesel truck. I would recommend an immediate re take! Also add some decent RPMs and WOT too if you don't mind.
I actually sounds pretty good. I think having it it next to one tip is making it sound weird at idle. It doesn't sound like that in person. The ones I have have recorded when the camera is mounted on top of the rear is much better. I haven't had a chance to convert this files yet. I really do like the exhaust.
Old 08-16-2014, 09:55 PM
  #220
speed21
speed21's Avatar
I'm sure it sounds good in real life....just that those clips really aren't doing it any favors at all TBH.
Old 08-17-2014, 03:47 PM
  #221
fygt
fygt's Avatar
Has anyone had experience with the AWE 991 turbo exhaust?
To me the EP exhaust note is a bit too deep - you can't really hear the flat-6 (with all its harmonics) through the exhaust like on a N/A 991. Admittedly this is purely based on their Youtube video where revs never go above 3500rpm, unless someone could point me in the direction of a better video which records the full range of engine speed?
It's so difficult to get a feel for how these systems sound without hearing them in person...
Old 08-17-2014, 07:27 PM
  #222
TT Surgeon
TT Surgeon's Avatar
The awe stuff is usually pretty decent, any clips of the ep yet?
Old 08-17-2014, 08:41 PM
  #223
Mark Currie
Mark Currie's Avatar
My GMG exhaust system is awesome. Throaty but civil at idle in normal mode. In sport mode lots of burbles when down shifting. It screams at WOT. Craftsmanship and fit is Perfect! Thanks Jerry@gmgracing.com for the great service and support.
Old 08-17-2014, 10:22 PM
  #224
speed21
speed21's Avatar
Originally Posted by fygt
Has anyone had experience with the AWE 991 turbo exhaust? Youtube video
Sounds good in the clip but can't say I was sold on the shot gun blasting (see at 2.42 and 2.50 onward). Is the one used in the clip perhaps a cat-less system?
I would agree youtube clips are not 100% reliable and the sound can vary depending on mic/type/position etc so it becomes virtually impossible to make a concrete conclusion. Always best to do a personal audition where possible.
Re the EP fwiw I can't say I've found it too deep at all actually. As a user my description would be; it sounds like an amplified version of the stock system from inside under throttle and at wot and from outside like an up-scaled 991S PSE with a heck of a lot of turbo whistle. Dealer and techs said much the same. I will say from out side it has some bark when you get up it that's for certain. In fact I would say the exterior volumes are probably much along the same vane as the AWE and GMG systems from what I've heard so far in their clips.
Agree. AWE is made and developed in USA from what I see and doesn't use any Chinese mass produced components so that is a good start.
Re the EP clip: only one I've seen so far is the one posted up on 6...and there is no WOT going on in that.
I will say though thankfully I've ever experienced any shot gun blasting going on with my EP at any time and that to me is a big plus.
Again these historically make a great sound and are genuinely developed and made in USA and use a proper crossover X design unlike some over rated over priced rubbish I've seen to date using restrictive chinese modular X pieces, so that is a real plus. The only real concern I would have is whether the GMG makes any shot gun blasting plus I'm not personally sold on any catalytic converters that haven't been properly insulated against thermal shock. I see a lot of users under estimate the importance that plays in performance and longevity. Probably doesn't matter so much if you never plan driving in the rain, snow, or go through any water puddles at any time into the future...
Old 08-18-2014, 01:22 AM
  #225
TT Surgeon
TT Surgeon's Avatar
Can you put up a clip of your ep, the one on 6spd is terrible.
Quick Reply: Consensus on stock exhaust and, who is considering getting an AM system?
