What scan tool to bleed coolant?!
What can I use to bleed the coolant system on a 991.2 TTS? I've had the thinkdiag and now the launch x431 ... Both advertised that I'd be able to do it but neither can (unless I just can't find the setting.... But I'm looking under special features)
Besides piwis, are there any other options? Any help would be appreciated!!
I looked on my launch x431 when I got it (~1 y ago) and it was not there. I have not looked since,, but I thought I saw an update for Porsche that mentioned it. Have you updated to the latest Porsche DIAG program?
I also noticed that the x431 does not do the oil fill process correctly for my 991.2 tts, it runs, brings it up to temp, but never shows a value after reading. I saw that was listed as fixed in an update too. Haven’t tried it since either.
i finally just flipped the purge valve open when it was cool, and went for a drive, when I got back the purge valve had flipped closed and I have not had any low coolant issues since. I think the dealer (non Porsche) flushed but did not do a proper purge/fill before me .. I was adding coolant in small amounts for 2-3 weeks .. went so far as to buy a new coolant tank … it is still in a box in my garage.
I tried to vac bleed the system and also let it idle with the valve up, but still overheats. Should I be leaving the cap off the coolant fill when I do that?
Yeah I just opened the box a couple of hours ago and immediately did all the updates. There was one that actually stated coolant bleed ...did that one and a Porsche specific one. Still no options. I'll toy around with it some more and see if I can figure something out.
Be aware that the factory coolant temp gauge is a lie (as is the cake) due to the factory programming. It will display 194 degrees for all real temps between 176.5 and 230.5 F
More info on this here: https://rennlist.com/forums/991/1283...t-the-fix.html
See my spreadsheet image below for how to get real temps displayed.
On the coding front, check out the spreadsheet image I uploaded here for some things you might want to do: https://rennlist.com/forums/991/1384...l#post19523446
I don't know about leaving the cap off.
Be aware that the coolant temp gauge is incorrect by factory programming. It will display 194 degrees for all real temps between 176.5 and 230.5 F
I have the thinkdiag and the x431 and was going to return both tomorrow haha... I don't think I dove deep enough into the thinkdiag. Would you recommend I keep it at this point? Any opinion on if it's better than the x431?
I didn't know that, but thought it was weird my car would all of a sudden jump up on the needle instead of of gradually going up. This makes sense now.
I have no experience with the Thinkdiag, I only have the x431, I got it before I knew/heard about the Thinkdiag. I do not have an android tablet, so I would stick with the x431 anyway. I have used the x431 on 4 different cars (each a different mfg), It has done what is needed in each case, except for the Porsche oil fill and coolant bleed. I posted in the Thinkdiag thread because it is a Lanuch product and the coding specifics seems interchangeable.
I sent a message directly to Launch asking about the 991.2 cooling bleed function and so far they only asked me "can you bleed it manually?" Lol....I told them I can but then I wouldn't need to tool -- still waiting for a response haha.
I did see that the x431 update specifically says bleeding the coolant is a new feature for the 992... So maybe 991s got skipped. Hopefully they can confirm it one way or another.
At the very least fix the lying coolant gauge before you return them
Please return to this thread with update after/if you get a response from Launch.
I Went overboard and also ordered an autel mk808, which just came in a few min ago. I'm going to try that now.
With the x431 I found some actuators that I cycled for the coolant, but don't know if they actually work or did anything. I did manage to remap the coolant temp curve
Now that I did that, what temp should my car read at during normal conditions?
Looks like we have a winner! Autel MK808s
Amazon link
I will say I liked the x431 pro version better...it seemed a lot faster. This is like the basic bare bones Autel scanner so a higher end one would probably be just as snappy. The original x431 was also the low model and was probably the worst. So it seems like maybe launch deleted the function for coolant bleeding somewhere along the lines. Unless I'm missing something --
So probably going to return the launches and the thinkdiag and keep the Autel...maybe upgrade to a better model, but the feature is there!!
Amazon link
Thanks for the updated information. Are “Short Tests” available under DME?
Normal temps vary for me. Normal and sport also behave differently by design, I was running 205-210 today in Sport mode. That is in 100 outdoor temp running down the highway.
IIRC Normal targets 215-220 to burn off condensation in the oil, while Sport/+ brings the 3rd radiator into the loop to target lower temps. 200-215.
Keep in mind the thermostat is electronically controlled too. And the control logic is different by driving mode.
I couldn't run the coolant bleed all the way, for whatever reason my post radiator temps weren't going up, so I think I have a bubble in the radiator I replaced and it's not letting everything circ back. The sensor was reading 96* the whole time (33*C) even as my engine temps ran up to 220. I'm going to jack the rear of the car up and run it again, and if that doesn't work, re-vac the whole system again.
I'll keep my eye on the temps. I guess Porsche programmed it the way they did so that the needle stays in the middle of the analog gauge during all normal operating temps. Thanks for all the info!!
Short Tests can help getting emissions monitors to a "ready" state to pass smog. It can set non-defective I/M sensors to a "ready" without the impossible to get right drive cycle.
See here: https://rennlist.com/forums/991/9459...l#post19575496
Did you do the bleed process with the vent/purge clip open? It is done that way when using PIWIS to trigger the process.
See the attachment in this post: https://rennlist.com/forums/991/1045...l#post15934092
Step 5.
Step 5.
