What did you do to your 991 turbo today?
#6586
#6587
Received 1,653 Likes
#6589
#6590
#6591
#6592
#6593
I did the Softronic Mygenius tune to my 2019 991.2 TTS
with catbypass pipes from Soul
however, I have yet to drive the vehicle as I had to leave to go out of town.
but I’m interested to feel and hear and see if there will be a difference
Big Swole (06-30-2023)
#6594
today was a Dussie!
here is what I have done so far, as of 10:30 pm
PLAN:
1. change out spark plugs
2. flush out brake fluid
3. remove the intercoolers ( will help with #1 above) and replace with the AWE larger intercoolers
4. remove the Y-pipe and the plenum and replace with IPD plenum and Y-pipe
so far, I have removed the drivers side intercoolers, removed the heat shield, exposed the 3 coils, removed them and replaced the spark plugs. installed the drivers side intercooler and then went to remove the plenum, y-pipe, and replace them with the IPD version.
Not so easy, but some parts done, some snags here and there
Tomorrow, I will tackle the passenger side intercooler and spark plugs.
the trickiest part was the plenum.
And, the tubing provided by IPD for the y-pipe does not jive well with the IPD y-pipe, so I will have to figure that one out
PLAN:
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_7912_d40c034c4a24bdc8a3e8749110e2b993028ff846.jpg)
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_7914_f15276febf85338a5855443ef19f6567c086d239.jpg)
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_7917_c9a323a63a2b461c245428b48bf67a9cd503cde7.jpg)
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_7918_f237470116a56baeabf34984c97d97d08049b37b.jpg)
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_7920_a1d41f998a6dd8baf21ba86e1d8a175aa13d253e.jpg)
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_7922_09c3c73c0e4dd721ef5aa81fde20919642bc0abf.jpg)
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_7922_ba56ebbc21821dadf62281d5e48beaea51fe073e.jpg)
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_7923_2_fd2de57457c538b4a8823b690b5cb6d0ac3370ee.jpg)
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_7932_140db4cb45988616590da5f8a90349ebb2071dd3.jpg)
#6595
I just did this, will this work?
This tubing came with the AWE intercooler, I cut it down to length.
The IPD Y-pipe has a tube adaptor, which I kept attached to the IPD y-pipe, i then slid the AWE tubing into this segment, and also used a clamp
final set up. Will this be a problem?
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/2000x901/img_7933_2_46f78d48e227f19213e0aa915a477ae998fc6baf.jpg)
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_7934_3_6345d7420db9ac0ada40b23121d6518c217af540.jpg)
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_7935_26301054bd94ee04e8e51fdd8ffe0cae7055010d.jpg)
#6596
Basic Sponsor
By the looks of it, I hate to say it, but I think that's going to be a problem. The small IPD supplied adapter is for connecting to the OEM pipes/tubes. When using larger aftermarket hoses, such as your AWE hoses, that small reducer piece is completely removed and the one piece silicon hose is connected directly to the IPD Y-Pipe. I think you are going to have to either get new hoses or use an aluminum coupler with clamps to rebuild the AWE hose to the correct length.
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
2022 Cayenne White
orthobird (07-06-2023)
#6598
That’s a boost leak. Definitely needs the correct parts.
orthobird (07-05-2023)
#6599
Flat 6 sells a pair of Silicon hoses for the IPD to AWE or AMS Intercoolers. I have them on my car and they work great.
https://flat6motorsports.com/collect...pipe-991-turbo
