What did you do to your 991 turbo today?
#5716
Question, does AMP still have sound restrictions for the PCA events?
#5717
Yes it still does unfortunately. But I run swing away pipes and just make it. I think we have the same exhaust systems. Ardent made mine.
#5718
#5719
#5720
They were great cars when they were running properly. I had a 1G awd Talon with a 50 trim that was really hard to beat for the money and then graduated to an 2G GSX with a built motor and 20g. That was my first “fast” car relatively speaking for the time.
#5721
Gotcha. Yeah I currently have the Kline 3" catless but with dumped external wastegates. So I think I am a no-go unless I also do turn-downs and recirculate the wastegate dumps. I might be in the minority, but I actually enjoy the sounds of the dumped wastegates. It takes me back to my DSM days. Check back in with me 5-10 years from now when I am picking out a set of hearing aids.
Yeah I have the same Kline 3" catless also. But still have the stock turbo's for the moment. I bet you car sounds awesome with the wastegate dumps. The Kline system alone sounds great can't imagine it with the dumps.
#5722
I almost bought a GSX back in the day; it pulled very well in stock form. Ended up buying a Type R instead, not the same turbo rush, but the screaming four banger had lots of grins per mile.
#5723
Likely better resale and reliability as well with the Type R. The GSX was very good at testing my patience along with ability to diagnose and fix issues on my own given I was ~18 and couldn't afford to take it to a shop every other week.
#5724
I didn't realize they were that unreliable; I thought the power plant was a direct descendent of the one Mitsu used in rallying.
#5725
#5726
No you are right, the 4G63 powerplant was phenomenal and eventually made its way into the Evo. It was more the small electrical and boost/vacuum gremlins which always seemed to pop up. The motor, even the stock one in my Talon, was a real trooper and put up with a lot of abuse from a bigger turbo and me self tuning with very little knowledge. The good old days with manual boost controllers and using DSM Link for fuel/timing control. I was the literal definition of the "maybe one more PSI" meme that always floats around. I am a little more reserved (but not much) with the 911.
That was my only effort to program a standalone.... went back to the factory ecu and Cobb, life has been good since.
#5727
I think they were unreliable - especially the 2G models with their weaker components. After upgrading to the standard sport turbo I decided against trying to build the motor and moved to a different platform altogether - mkiv Supra.
#5728
The Supra had a fantastic engine in it, knew a guy from Calgary that ran one in One Lap, not a single issue, pushing 900hp. Neat toy.
TeesTurboS (11-04-2022)
#5729
Built a 2JZ-GTE (Supra) motor for a Lexus SC back in 2010. Made 1050RWHP on E85 and a ProEFI standalone. Beast of a motor in its day and still one.
Pb Pedis (11-04-2022)
#5730
Got around to installing my Kline Inconel headers and Kline Inconel exhaust (Thanks to Sam for hooking me up with this 'Exclusive' version of the Kline Inconel exhaust) this last weekend. Just installed a Sam, By-Design tune. Looking forward to better sounds and more ooomph!
