just got back, let's discuss value of porsches
#5761
GT3 player par excellence
^ the 993C4s is pissed at you for not showing
it may very well break down tmo
I see u have two bucket method
let me corrupt you with power washer and foam gun
forget the buckets
iirc you have master blower already?
if not get the 8hp one, buy two, one each hand. much faster
forget the buckets
#5762
signal orange 914/6 2.7L
signal green Sagan venue DA Di2
911Jetta (02-18-2020)
#5763
who needs **** when you have this
#5766
on watercooled it’s called ruby star
in aircooled it’s actually ruby STONE
#5768
#5769
I test drove a Taycan Turbo today. I'm quite impressed. The seating position is spot on and it's easy to place the car just where you want when cornering. Feels almost like a big 911/Cayman, but hides the 195 inch length, 77 inch width, and 5000+ pounds with the low CG, low driving position, low dash, and 911-esque hood that falls away. The suspension design is also a standout. It does the dual-purpose trick of firm and controlled cornering, with a supple ride over bumps, better than anything else I've driven.
I've test driven a model S as well. That was a dull car, but an impressive gadget. As a driving experience, there is no comparison with the Taycan. Also, if you haven't seen, here's how the performance over several quarter mile runs compares between the two. The engineering of the thermal management on the Taycan is light years ahead of the Model S.
Also, in a real world test of range, it's quite comparable with the Tesla, so there's only a small hit for much better performance (.99 skidpad vs. .92, 16.5 inch front brakes vs. 14.0 inch front brakes)
#5773
but I do prefer the slower fragrance of petroleum
#5775
