OFFICIAL 991.2 GT3 RELEASE *Confirmed 500HP 4.0 & Manual option*
#1381
#1383
In real life photos the option where the AC vent slats are painted looks relatively better than the AC vent frames. The builder makes the latter look very heavy-handed but real life is OK and more subdued. The 3D builder when using the "+" option to look directly gives a bit of a better impression.
To clarify: both AC vent paint option have the non-painted portion on leather. Frame painted - slats are in leather. Slats painted - frames are in leather. There is visible stitching on those frames when they are in leather (slats painted).
To clarify more: I spent too much time looking at Porsches.
Similar to painting the Vent Frames, can the Vent Slats be painted in a deviated color. For example, if you didn't want the standard aluminum color or the painted exterior color, you could get black so it blends. Anyone do this? CXX option?
#1384
Just so you know, the CXX and PTS authority has a stickie here:
https://rennlist.com/forums/991/7085...e-and-you.html
A vent slat thread? Who knew. Cool! Thanks Mass27 for digging that up.
https://rennlist.com/forums/991-gt3-...r-slats-2.html
Very good info and a great resource. The guru sometimes comes out and answers questions.
I hear he lives somewhere in a cave high in the AZ mountains surrounding PHX.
#1385
A note re: buckets- good idea to sit in them before you order and subsequently find out you don't fit.
That is all.
That is all.
#1386
Question for engineers or someone smarter than me at cars...
The bore (81.5mm) and stroke (102mm) for both the 991 GT3RS and 991.2 GT3 are the exactly the same; however, the compression ratio for the RS is 12.9 while the 991.2 GT3 is 13.3.
How can power be rated the same between the two cars if the GT3 has a longer stroke? What else is at play? Sorry if dumb question.
#1387
BTW, you have bore and stroke swapped. 911's have very short stroke relative to bore...
Since the 991.2 GT3 has same displacement and higher compression than RS (and less internal friction from solid valve lifters), I would expect it to have at least 10 to 15hp more power (and more torque) than RS at rest on the dyno, where the power is rated. RS probably gets a bit more ram-air effect from side intakes, but this is not part of the 500hp rating.
I think the GT3 has identical power and torque numbers as 911R and RS, to avoid political issues associated with the new motor bypassing those models.
#1388
Given the end result is more compression, though, does that not result in an increase in power? Regardless of whether it's due to the dome or not?
#1389
Flame suit on:
1. Make sure they are wife approved.
2. No heated seats on buckets. Yes, I know, who the hell needs heated seats. See point #1.
3. Bucket seats are very comfortable once you are actually seated (assuming you have the body type/size that fits in a bucket seat). Anyone who says getting in and out of them is easy, is not being honest or accurate. So, if you plan on going to the dry cleaner or grocery store or ANYTHING other than the track which requires multiple ingress and egress, do not get bucket seats. Once again, who the hell cares about comfort and errands. See point #1
Flame away.
#1390
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/640x1136/80_image_d4e9c96293d469594e4092012afd74bc467787c9_1e4c227b7d5499bf1dc74cdeffa242832095a781.png)
In that car apparently, the redlines are -
1st 2nd: 8800
3rd: 8600
4th+: ~8400
https://rennlist.com/forums/991-gt3-...l#post13376567
So probably means something similar for the .2 manual - 9000 in 1st and 2nd and somewhere in between 9k and 8.5k for the rest of the gears?
#1392
Not necessarily. The new valvetrain and better oiling may have convinced the engineers that reliability no longer depends on that sort of thing...
#1393
#1394
It could be measured (or calculated) by knowing the absolute air pressure in the intake plenum at high road speeds (I think the engine's ECU is sent this info from sensors to adjust the fuel mixture, so it would be known).
#1395
Originally Posted by mass27
+1
Flame suit on:
BUCKETS
Flame away.
Flame suit on:
BUCKETS
Flame away.
Definitely not a "one size fits all" option literally. I agree.
I like, but there are a lot of different situations every buyer is in and can understand they're not for everyone.
Now, the no-wingers that's another story
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
