Noise from rear of RS
Not the exhaust ![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
When hitting big bumps I get the usual cage creak but also a dull thump too on the NSR, it might be usual, I cannot see anything loose, the car is brand new?
These cars do seem to give off a lot of road noise & you hear every stone/chippon you driver over
If a thump it could be the rear deck/lid adjustment required. Same issue on many GT3's. Minor adjustment to the two bushings should sort it out.
Ah I have been getting this exact same issue since I bought my car.. A dull thump is the best way to describe it. I thought it was normal as it sounds a bit like rear wheel is rubbing.
Thanks for the info. Will try to sort it out tomorrow morning.
