991 GT3, GT3RS, GT2RS and 911R 2012-2019
RS Rear Deck Rattle
Old 12-30-2015, 11:46 AM
awew911
awew911's Avatar
Default RS Rear Deck Rattle
So after about 300 miles, I started hearing a rattle coming from the rear of the car when driving over any bumps (ie. driveway entrance / pavers / etc). The noise was much more pronounced when on a slight angle and when the rear right wheel traversed over the bump. This occurs at low speed (< 5mph) but the noise was audible at 70 mph as well.
When I opened the rear lid, the noise went away.
I could reproduce the creaking by pulling back ever so slightly on the rear wing.
Examining the two adjustable posts towards the front of the lid showed wear marks on the forward part of the posts. The hinge for the rear deck sits on top of these posts.
I placed two pieces of rubber on top and the noise went away.
I wanted to post this here if anyone else runs into this issue.
Old 12-30-2015, 12:08 PM
Jimmy-D
Jimmy-D's Avatar
Received 1,450 Likes on 754 Posts
I think some had this issue with the 991 GT3. I think you can adjust the (2) black rubber pieces so that it is more flush when you close and rattle will end.
I think the RS would have the same pieces.
But you may want to wait for more input because it is easily corrected
Old 12-30-2015, 12:16 PM
awew911
awew911's Avatar
Yep. Tried adjusting the rubber posts on the lid (13mm nut) at various positions with no success in reduction of the creaking noises. Clearly there may be an adjustment needed on the front posts. The noise was so clear that I was prompted to investigate the suspension components to make sure everything was tight.
My 991 GT3 doesn't have this problem.
Old 12-30-2015, 05:02 PM
bronson7
bronson7's Avatar
I had a bit of a noise on my 3, made the slight adjustment and all has been well ever since.
Old 12-30-2015, 05:09 PM
awew911
awew911's Avatar
I didn't try to adjust those since they were painted (as if it's preset by factor and not design to be played with). The rubber pads solve the problem, so I'll probably leave those and see how it goes.
Old 12-30-2015, 06:24 PM
MileHigh911
MileHigh911's Avatar
Great solution. If those posts are stopping posts for the lid, I am surprised that Porsche didn't have a rubber cap.
Old 12-31-2015, 06:59 AM
Kobalt
Kobalt's Avatar
I can not look at my car as it is in hibernation but I think it looks strange that these parts are painted.
Can someone with an RS check their car: Is it painted for you too?
Old 12-31-2015, 08:09 PM
signes
signes's Avatar
Mine was doing the same but it was created by the hard rubber to rubber contact from the supports at the rear of the lid. The painted studs shown above are the same on my car but are at the front edge of the lid and don't seem to bear any weight at all. When I complained about the noise the dealer added felt to the top mount. There was something in his system about it so it seems like a common complaint.
Old 12-31-2015, 08:48 PM
Kobalt
Kobalt's Avatar
Thanks!
Old 08-22-2021, 03:33 PM
kamc
kamc's Avatar
Default Rear deck rattle
My 991 Gt3 had the same issues, rattle from the rear deck couple of months back. Adjusted the rear12mm bolts, seemed to sort it.
Quick Reply: RS Rear Deck Rattle
