garage car lifts
#737
Originally Posted by sonorous
I believe he means the 888LM control panel. I also had one fail at one point and replaced it myself.
#739
Wow that’s tight!!! You must almost touch the ceiling when your raising the lift before you let it back down to let it lock.
#740
Yeah it's the 888LM (which comes stock with the 8500), literally this one on Amazon:
If it fails none of the remotes will open or close the door, nor will the wall panel button. You'll think your system is totally hosed. Door can randomly open when it's in that state (we watched it do it on our security cam). Original installer came out and was like yeah, they can do this, and replaced it temporarily with a single button dumb panel while he ordered the replacement. Takes two mins to replace, and I ordered another one so if it happened again I was covered. Ours was only five years old when it happened. Dunno if they have a random fail rate or what, but installer was not surprised at all.
Liftmaster 888LM Security+ 2.0 MyQ Wall Control Upgrades Previous Models 1998 (and later), Black - Garage Door Openers - Amazon.com
#742
I put in a high rail kit and 8500 on one of my doors. It used to randomly open when I had it hooked up to wifi. I presume randomly. Since disconnecting it I haven't had issues. Then last year it kept loosing its bottom limit settings and wouldn't close all the way. It meant having to retrain it every time which got old. They replaced the whole control unit, works fine for now but hasn't gotten much use through the winter. It's only been 2 years. Have read many complaints online. Not sure why so hard to build a good quality opener.
Anybody know of commercial solutions that can work in residential applications? Not to replace mine but for future installs.
#743
definitely tight just enough space to get it off the locks without touching. If you get up and look sideways it is about 2 inches or less clearance!
#744
Thanks for both of your recommendations for the sliding trolley jack. Looking at the photos, the width of the jacks appear static, and you can slide them from front to back. Are the width of these adjustable so that you can use the jackpoints, or do you jack on the undercarriage of the car? Thanks.
#746
Other item to be aware of is, do you want a manual jack or air. I tried manual then switched to air powered as there is not that much room under there to crank the jack.
#748
Does the jack slide forward and backwards fairly easily? It is hard to tell from the images. I know the Benpak jack has wheels that engage some inner rails. But the Bendpak is overkill for my use case.
Does the Pro Jack sit on these feet?
Or does it sit on this metal arm?
#749
The direct lift sits on the top part of “L” bracket — it has a thin piece of hard slippery material on the underside that allows the jack to slide along the ramps (you can see it both in my picture and the marketing picture taken off their website). The arms that the L bracket attaches to are adjustable to fit various width lifts. You tighten the silver hex head bolt above the hydraulic line of the hand pump when you have the sliding arms adjusted between your lift ramps.
#750
Bend Pak makes an RJ45 series (think they make a low profile and normal version) bridge jack. I have two of them on my HD9 and it's an amazing setup. You can get under the car for all types of service work, and then you can put the car up with its wheels raised off of the lift for suspension access, and you can raise the entire setup by raising and lowering the entire 4 post.
