911R Weight Reduction
#319
Basic Sponsor
Hello Bob
It has been years since we have spoken. I can not believe that I have not discovered this thread on RL about weight reduction.
All the best
Rodger
All the best
Rodger
https://www.orbitracing.com/
#323
what is the R weight down to now as it stands ?
#324
It would be great to have list of parts, weight saved, cost per part and cost per lb saved. Some people would want to get the most value ie lowest cost weight savings in the right areas of the car and other will want to reduce weight at any cost. For example the lithium battery is probably the lowest cost per lb saved option so easy. PCCP's might be the most impactful and so on but there might be several items I would buy in an effort to further lighten the car but I'm not trying to win races so not going to throw any amount of cash at the weight problem. For you guys who say just hit a treadmill, I already do and that isn't the answer.
#325
Can anyone comment on best exhaust option (with cats and valves) for weight (amount saved?) while maintaining character of engine sound? Thank you
#327
Oil Tank Installed. RPT calipers tested for fit. Hope to have real calipers in a month. Next come front and rear drop links, carbon fiber air filter box, carbon fiber induction plenum and then, if possible, carbon fiber gear box.
#329
Robert, kudos on this project ... please keep up the sharing and ... THANK YOU
