New PCCB and Track days – Facts Feedback Thread
#121
I'm hoping that as more reports of the Gen 3 PCCBs come on we can put to rest the notion that ceramics are bad for the track because of the cost of replacement.
One can still argue that iron rotors are subjectively better than ceramics because of pedal feel, and that's certainly not an invalid position to take.
But suggesting that PCCBs are not appropriate for heavy track use because they were (historically) price prohibitive may be an outdated notion.
I, for one, would not spec a GT car without PCCBs. But then I like deviated stitching too.
#122
#123
#124
Bump for updates!
I'm on the fence with pccb's and hoping more owners have logged miles could chime in to provide their input, towards the longevity of the Gen 3 pccb's.
-I'm looking at 70% street (winding roads & twisties) 30-35% (4-8 days/Year) track/lapping days. I'm not particularly hard on my brakes when behind the wheel.. so I would really love to hear more about the current Gen 3's.
#125
Bump for updates!
#126
Quick question how different is the pedal feel from iron to pccb? I had a 997tt with iron and now a 3 with pccb, I feel like i have to push the pedal much harder with the pccb. Is that normal?
#127
11k miles, 3+ track days (I don't know how many the previous owner did, but they primarily tracked the car and it was driven by pros), 16 autocross days.
It looks like the rears are taking more of a beating than the front. This is the first time I have gotten these readings and I got them with a new set of tires. Next time I get tires i'll have them read again.
Left Front 1: 51/38/47.40 (72%)
Left Front 2: 59/44/57.9 (72%)
Left Front 3: 59/44/55.1 (74%)
Right Front 1: 63/47/58.6 (73%)
Right Front 2: 65/48/60.5 (73%)
Right Front 3: 57/42/53.4 (76%)
Left Rear 1: 58/45/53 (61%)
Left Rear 2: 59/45/53.4 (60%)
Left Rear 3: 62/47/57.7 (71%)
Right Rear 1: 62/47/57 (67%)
Right Rear 2: 60/46/57.7 (84%)
Right Rear 3: 60/46/54.2 (58%)
#128
Could they be cold? I noticed a much better bite with the PCCBs on a 991 GT3 than with irons on a Carrera.
#129
That is definitely not my experience - I have iron rotors on a Panamera, and PCCBs on a Cayenne and the GT3. The PCCBs definitely lack feel when they are cold or initially when wet; but once at operating temperatures I do not notice much difference in the pressure required. They is a subtle difference in feel, but in day-to-day use and on the track you have to think about it to recognize it. I actually think the PCCBs "feel" better too me & both are equally capable of stopping the car at any speed.
#130
In my experience (I will have three samples to report by the end of the track season this Fall -- two samples are reported above), I believe that the rate of wear might decline slightly from the initial wear; perhaps that's wishful thinking but more information like your data above will help find the answers.
#131
Here is more data -- I have had the PCCB rotors and pads checked twice by the same Porsche dealer but two different service techs. The first came after 5 tracks days (486 miles -- 4 at Sebring a 1 at Lime Rock) and 4,792 total miles. The second came at 6 more track days (705 miles all at Lime Rock) and 8,670 total miles.
I wish I had measured the rotors when the car was new. I suspect that the change between the "new figure" numbers, which are etched onto the rotor hat, and the first readings at 4,792 miles may represent initial break in wear as much as the 486 mile track wear. There is not much apparent wear between the first and second readings when the car spend 705 miles on the track; is it possible that initial wear is higher and once the rotors are "broken in" the wear slows down?
Obviously there is also some variability in the readings because some of the second readings are higher than the first readings +/- 5%??? Only the first reading on the Left Rear is way off?
#132
Very important to know if these miles are ran with PASM/TC on, PASM OFF/TC On, or with all turned off. This will change the amount of wear the rotors see since the system uses the brakes to keep the car in check.
#133
#134
The one time I turned them off was on an AutoX in the rain, and I was trying to master power-on oversteer. Before I knew it was happening, I spun off the track at a low speed but hit the turf hard enough to demount a rear tire but fortunately not hard enough to do other damage.
#135
I agree -- it's very noticeable when they are cold. I notice it every morning leaving my house, there is a hill at the bottom of my street where I first apply the brakes and I have learned to feather the brakes as I approach the stop sign. Less of a problem on warm summer mornings - not sure why.
