Is it true? No R compounds to be used on a 991 GT3?
I thought it was a CL issue. To avoid the PIA that Porsche went through replacing CL on 997s??
Id doenst say any such think the manual.
Yes R6 have been run successfully on this car by at least two on these boards (est8esq etc). Both using 19" fitments no issues at all.
It sounds like these non Rennlist guys tracking the GT3 with R6 need to get onto this board pronto and find out a bit more about the cars. If the ECU detects a variance between front and rear rolling radius by more than 5% it will retard ignition. It is why its not so easy to throw this rig on the dyno (only one see of wheel moving also confuses ECU)....
This is the info I got when I asked what was the problem from a guy close to PCNA:
"Tell him to read the owner's manual, it describes the issue there.
Too much torque on the motors causes them to switch to a Limp-home-mode that takes the dealer to reset."
Not sure I understand? Will probe for more...
But again, all the responses above are speculation and what people "think". What about real world experience?
Basic Sponsor
Thanks Guys
Macca, not trolling at all. It was/is a serious question. Last weekend at Petit LeMans I was talking to a friend of mine that had just recently done some instructing at VIR. A couple guys - unrelated to each other - had brought their new GT3's with brand new sets of Hoosiers. Every one of them had issues as described above with the car going into limp mode. But, I do not know the tires sizes so I can't comment on that, so yes that could be the problem.
My friend - who is very well connected within PCNA and owns multiple very high end Porsches (not a 991GT3 though) was curious so he asked around and was told what I posted above. I relayed what I had heard to another buddy of mine who DOES have a new GT3 and he was a bit concerned as he was just planning to buy a set of Hoosiers. He spent all week trying to corroborate or dispute this information and found nothing.
So...I thought I would help him out by going to the obvious foremost authority on all things Porsche - Rennlist!!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
However, it seems that my simple question was met with a bunch of people that feel they need to constantly defend the almighty GT3. That was not my intention, I was just asking a question based on real world experiences that were had and was trying to help a friend by determining if similar experiences were found elsewhere.
It was mentioned above that slicks are prohibited. Any reason as to why?
Bob Saville
![](https://naroescapemotorsports.com/wp-content/uploads/2018/01/naroescape-logo-small.gif)
Getting You On Track!
www.naroescapemotorsports.com
704-395-2975
'07 SPC
'71 914/6 Huey
'04 GT3
Bob Saville
704-395-2975
- Data Analysis & Coaching
- Drivers Gear
- Crew Gear
- Car Gear
'07 SPC
'71 914/6 Huey
'04 GT3
Guys - I do not know much about this stuff but why does the computer put the car in limp mode? Is it because it detects some thing unsafe?
I also guess any one trying to screw with the ECU( like a software upgrade) - aint going to happen like you could do on previous variants?
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,268 Likes
Let me throw my hat in here....first I doubt it's the ECU more likely the BCM. Variance between front and rear are assumed to run within a certain parameters, if out for an extended time then ECU is told to take action.
Understand that the BCM uses the wheel speed sensors for ABS TCC calculations and if the data makes "no sense" then proper calculations for ABS and TCC can not be preformed so BAM...limp mode.
Thanks naroscape. In the future just tell the owners of those 991 Gt3 to join up and we can help them directly. That way the facts are on the table and guys like you don't get cruising ode as the middle man....;-)
The reason slicks are exempt on this car is simply due to warranty liability nothing more as had been touted by the unwashed. I got this from the horses mouth a few weeks ago. For the first time Porsche openly extended wAranty to use on track however slicks multiply loads by sizeable factors and I'm assuming the finance department wanted a caveat so an engineering line was drawn. It's nothing to do with RWS motors and the under pinning a of the suspension are much beefed up over the prior gen as chuck Moreland will tell you as it shares much with the 991 cup. I can't blame them either - slicks create massive lateral loads - they are a business and I would cap my liability to if I was them....
I can corroborate that you can use Hoosier R6s in 991 GT3s. I know because I ran with one on the track 2 weeks ago. And it was one mighty fast car, I must say! ![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Probably wrong tire sizes for the cars going into "limp mode". Aforementioned GT3's owner did have wheels specially ordered so he could fit Hoosiers.
Key: the ratio of tire diameters needs to be consistent when you change to different tires than OEM. Many cite 3% as the max tolerance number. Put another way, if OEM 991 GT3 tire diameters are (random numbers) 25" in front and 26" in rear, the Hoosier diameters need to be something like 24" F and 25" rear. If you put tires that are 24" F and 23" in rear, the PSM will have a heart attack and not let you drive (constant braking and cutting throttle).
Coincidentally, there was a 981 Cayman S that was having this exact problem at the track. One of the guys from the group that I track with tried using BFG R1s but PSM shut him down. Note that the BFG R1s were correct sizes for 987 but this 981 would have none of it. 981 OEM tire diameters must be different than 987's. I let him try out my set of used Hoosier R6s and those his car had no problem with.
Given this and the on-track warranty you can see why they are reluctant to ok slicks...
Basic Sponsor
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
[QUOTE=the_vetman;11715573]I can corroborate that you can use Hoosier R6s in 991 GT3s. I know because I ran with one on the track 2 weeks ago. And it was one mighty fast car, I must say! ![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Thank you for this information it's very helpful.
Would you share with us what brand your wheels are?
Are they center wheels or did you change to 5 lugs?
What size's tires are you using?
What Brand Hoosiers?
GT3 player par excellence
1. i think it's diamter issue. this was encountered on my 997.2RS as well. once sized right, no prob
2. as far as most trackers are concerned R6 is NOT slick. it has very little grip compared to "slicks" like yoko, michelin blue etc
