991 GT3, GT3RS, GT2RS and 911R 2012-2019
Consolidated 991RS thread
Old 07-23-2014, 01:09 PM
  #1021
Larry Cable
Larry Cable's Avatar
Received 3,631 Likes on 2,357 Posts
Originally Posted by <3mph
Are you suggesting the vents on top of the rear behind the rear window
could be used as intercooler vents?
No, and yet yes, consider the following:
- the mule has no characteristic GT ram air structure on the rear decklid merely slats found on other 911 variants
- therefore, how is air inducted to the engine:
1) forced induction via turbocharging
2) natural aspiration:
a) drawing air into the engine compartment thru the decklid slats
(which has no associated ram effect seen on other GT variants to date)
b) air ducted from the side (turbo S) flank intakes on either side of the
car, behind the doors, in front of the rear wheels, with some ram effect
from the location of the intakes drawing air flowing over the flanks of the
car
IF, the engine is turbocharged it requires intercooling, this has been engineered in two ways for the history of 911 Turbos:
930-993: a single large intercooler situated above the engine, vented through the engine decklid
996-992: dual intercoolers, situated one on either side of the engine, one per turbo, per bank of 3 cyls, mounted low down to reduce ctr of gravity, and vented through slats in the rear bumper cover (a design pioneered by RUF I believe)
There are no characteristic 996- style intercooler vents on the rear bumper of the mule, therefore its likely its N.A or Porsche has returned to the 930-993 style of single large intercooler design, highly improbable for a variety of reasons, hence I assert its N.A drawing air from the side ducts.
Old 07-23-2014, 01:34 PM
  #1022
neanicu
neanicu's Avatar
I've said it before,I vote for(or would be nice to have) air being introduced thru the side inlets with individual throttle bodies for each cylinder.
Old 07-23-2014, 01:42 PM
  #1023
Larry Cable
Originally Posted by neanicu
I've said it before,I vote for(or would be nice to have) air being introduced thru the side inlets with individual throttle bodies for each cylinder. : thumbup:
I'm guessing your former wish is granted, less certain about the latter, for reasons of cost and relative resulting improvement of engine perf
Old 07-23-2014, 01:54 PM
  #1024
neanicu
neanicu's Avatar
The individual throttle body set up is very interesting IMO. I have it on my E46 M3. I believe with today's electronics you can achieve more power and better fuel consumption in a high revving NA engine.
Another interesting design I'm dying to see soon on production vehicles is the electronically controlled valves.
Old 07-23-2014, 01:57 PM
  #1025
Larry Cable
it would be a real change for 911 production engines
Old 07-23-2014, 02:05 PM
  #1026
neanicu
neanicu's Avatar
Yes. Maybe it's time for some changes...
I believe there are or will be better solutions in the future rather than going full blown turbocharged. I think turbocharging is the cheapest readily available solution to escape regulations. Maybe it's time for engineers to go back to the drawing board and use their collective minds for a better solution when it comes to enthusiast cars.
Personally,I'll take a hybrid combined with NA engine any day over a turbo.
Old 07-23-2014, 02:10 PM
  #1027
Larry Cable
heretic!
Old 07-23-2014, 02:20 PM
  #1028
GrantG
GrantG's Avatar
Received 5,094 Likes on 2,869 Posts
That's the way they always used to be for the first 10 years of production (starting with the 6 carb intakes in 1964 and ending with the Mechanical Fuel Injection cars in 1973).
Old 07-23-2014, 02:25 PM
  #1029
Larry Cable
totally understand that, I think the throttle bodies per cylinder went away about the same time as MFI came in - doh like you said!
Last edited by Larry Cable; 07-23-2014 at 02:26 PM. Reason: Doh - like GrantG said ...
Old 07-23-2014, 02:27 PM
  #1030
GrantG
GrantG's Avatar
totally understand that, I think the throttle bodies per cylinder went away about the same time as MFI came in?
Nope, MFI always used 6 throttle bodies with velocity stacks (first made from Magnesium like above and then changed to black plastic). MFI was the system from 1969 to 1973 (still my favorite for intake sound, power delivery, throttle response and the ability to adjust for temperatature and atmospeheric conditions like altitude - it was an analog computer and rock-solid reliable).
CIS injection was the one with just one throttle and it sucked compared to what came before (necessary for emissions and economy).
Old 07-23-2014, 02:28 PM
  #1031
Larry Cable
cool - learned something new today!
Old 07-23-2014, 02:40 PM
  #1032
neanicu
neanicu's Avatar
Thanks for your input GrantG,always valuable!
What do you think about individual throttle bodies with today's technology in a high revving 4.0L NA engine?
Old 07-23-2014, 02:43 PM
  #1033
GrantG
GrantG's Avatar
It would be absolutely Epic! They've continued to use it on all the GT3 RSR's and it kicks ***!
Old 07-23-2014, 02:45 PM
  #1034
neanicu
neanicu's Avatar
It would absolutely Epic!
That's what I thought!
Porsche! Are you listening?!
Old 07-23-2014, 02:48 PM
  #1035
Larry Cable
then it could be a feature on the RS seeing as it appears may be re-using some of of the RSRs intake technology.
Quick Reply: Consolidated 991RS thread
