991 GT3, GT3RS, GT2RS and 911R 2012-2019
Consolidated 991RS thread
Old 04-25-2015, 09:58 AM
  #7936
Shahano
Shahano's Avatar
I used to professionally drive F3, and trust me than no car in the world will ever have the same downforce as an F3, let alone an F1 car.
5G under braking and around 4Gs in corner.
Old 04-25-2015, 10:01 AM
  #7937
Backroads
Backroads's Avatar
Originally Posted by Ronan
Well..the F1 cars are just a tiny bit quicker.... Video Link: https://www.youtube.com/watch?v=Ex5dhhpSHCw
Holy Toledo! Hadn't seen that before. Kinda puts things in perspective.
Old 04-25-2015, 11:07 AM
  #7938
shapiroeric
shapiroeric's Avatar
I would agree there is a speed differential but I don't think that video is accurate....either the F1 is sped up (my guess) or the GT cars are slowed.....it's obviously a heavily edited video.....
Old 04-25-2015, 11:12 AM
  #7939
Jon70
Jon70's Avatar
Also, the F1 cars aren't exactly following the track. Looks like the overlay may just be off.
Old 04-25-2015, 11:28 AM
  #7940
Loess
Loess's Avatar
I guess I wasn't saying the gt3rs was as fast or has the same aerodynamic downforce as an F1 car but the fundamentals of aerodynamics are the same at 20mph as 200mph. If there was no effect I don't think Porsche would use the rear wing or front louvres. Unfortunately I don't have any wind tunnel data to support my belief that dropping the front and raising the rear of the car has a measurable effect on downforce/reduced lift.
I'm sure a rear diffuser would help as it would work the same way (venturi) to decrease the pressure under the rear. I think the common slats are just to clean the air unless they widen out laterally as well.
I'm just trying to propose a reason for the apparent higher back end of the gt3rs.
Old 04-25-2015, 12:27 PM
  #7941
carcommander
carcommander's Avatar
Need to update the avatar.
Eau Rouge Overlap - Forumla 1 vs FIA GT cars - YouTube
Wow. What a great illustration.
Old 04-25-2015, 12:36 PM
  #7942
1198r
1198r's Avatar
It does indeed look high (even more so on the pics of Weber going round the ring). Certainly on the LO car can't help but think the black lower trim gives visual impact its higher - it wraps around more than on the GT3. Reckon if it was same colour it would not look so bad.
Old 04-25-2015, 08:34 PM
  #7943
bronson7
bronson7's Avatar
Neat video, but I find it somewhat hard to believe it's truly accurate. If it is, then I'II say....HOLY ****.
Old 04-25-2015, 08:56 PM
  #7944
usctrojanGT3
usctrojanGT3's Avatar
Received 4,070 Likes on 2,326 Posts
If true it looks like the GT cars are doing a parade lap compared to the F1 cars...totally different lines too.
Old 04-25-2015, 09:34 PM
  #7945
NateOZ
NateOZ's Avatar
Originally Posted by home7271
The aerodynamics on a F1 car is undoubtedly very complex. Generally speaking, I believe the bottom of an F1 car is level with the ground. The diffuser in the back of the car is what helps accelerate the air from the bottom to help with the downforce. The rake you mentioned may be due to heavy braking.
Don't think the RS has much in common with an F1 car with regards to the underbody aerodynamics.
The downforce is a function of the angle of the diffuser and height above the ground. Rake was actually set in the chassis during part of the RB7 heyday, but the regulations have changed now requiring the angle of the diffuser to be reduced if the height is increased.
There is no advantage to running rake now due to these regs.
Old 04-25-2015, 10:27 PM
  #7946
Nizer
Nizer's Avatar
Received 1,886 Likes on 972 Posts
Did someone mention downforce?
Old 04-26-2015, 04:54 AM
  #7947
home7271
home7271's Avatar
NateOZ, you are correct! Found this article and it explains very well how the RB F1 cars ran higher rake angles and made it work better than the rivals.
http://www.formula1-dictionary.net/rake_angle.html
Old 04-26-2015, 11:46 AM
  #7948
Loess
Loess's Avatar
Good article. I wasn't sure how they were using the exhaust. It would be much easier to run deep side panels on the exterior of the diffuser if the rules permitted.
I believe they are still running rake. It's not all about the diffuser. F1 is governed by a ton of rules. They could do so much more with these cars but I understand that budget and speed/safety are real concerns.
This photo shows the front under panel literally on the ground with the back way up. Is Porsche doing this on the RS?
Old 04-26-2015, 02:06 PM
  #7949
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Check out the 10 minute wind-tunnel video that was just posted the other day in the racing forum OVER HERE. Not an RS but the principal is the same.
Old 04-26-2015, 07:24 PM
  #7950
Kain
Kain's Avatar
Sorry if this has already been discussed but what does Lava Orange really look like? I've seen pics where it looks like pure bright orange whereas in other pics it looks like a pale or washed-out orange.
Quick Reply: Consolidated 991RS thread
