991 GT3, GT3RS, GT2RS and 911R 2012-2019
Consolidated 991RS thread
Old 03-23-2015, 04:46 PM
  #7066
Nizer
Nizer's Avatar
Received 1,889 Likes on 973 Posts
^^Bascially ground clearance, suspension travel, spring rates, and downforce.
Still waiting on GT Silver.....
Old 03-23-2015, 04:51 PM
  #7067
9972RS
9972RS's Avatar
So rs has a good deal of suspension travel to accommodate the high downforce? The high suspension travel to make it more comfortable on the road?
Old 03-23-2015, 05:17 PM
  #7068
Nizer
Nizer's Avatar
Yes. And I should've added tire diameter as another differentiating factor.
For example the Cup rear tire is a 31/71-18, which has an overall diameter of 27.8" whereas the new RS is spec'd with a 325/30-21, which has a diameter of 28.7". Almost an inch taller.
This photo from last weekend's Sebring IMSA race gives a good sense of just how much lower they run the GTD class 911's.
Old 03-23-2015, 05:29 PM
  #7069
GregJGT3
GregJGT3's Avatar
For example the RSR rear tire is a 31/71-18, which has an overall diameter of 27.8" whereas the new RS is spec'd with a 325/30-21, which has a diameter of 28.7". Almost an inch taller.
The net result of the larger rear tire diameter is more speed at any selected gear/RPM combination compared to the 991GT3 or earlier cars with smaller rear tire overall diameter. If you have the torque to support it the new 991.1 GT3RS will be a faster car, i.e. faster speed at any point in the gear range. Now since the reported redline is lower in the GT3RS perhaps Porsche is planning marginal gains in speed with lower RPM when compared to the GT3.
Old 03-23-2015, 05:36 PM
  #7070
Dante
Dante's Avatar
in my opinion such a higher rear (with the flat underbody panel) could be a hint of diffuser with aerodynamic purpose as we can can see in mid engine cars..
Old 03-23-2015, 05:43 PM
  #7071
TRAKCAR
TRAKCAR's Avatar
Received 1,673 Likes on 776 Posts
It sure looks dragster insane.
Old 03-23-2015, 06:22 PM
  #7072
kyrocks
kyrocks's Avatar
Don't like the white.
Old 03-23-2015, 06:32 PM
  #7073
rockitman
rockitman's Avatar
poor picture...white balance is off...White would match my Cayenne GTS perfectly...however, I am ballz out magma if my allocation/build comes through...
Old 03-23-2015, 06:39 PM
  #7074
RBH
RBH's Avatar
+1, F-ing Instagram filters
Old 03-23-2015, 06:46 PM
  #7075
Nizer
Nizer's Avatar
Diffusers are useless unless they operate very close to the road surface; rear of the RS is well above the functional threshold.
Now you're talking.
Old 03-23-2015, 06:56 PM
  #7076
rockitman
rockitman's Avatar
Regardless of ride height, this car will be the fastest around any track of all GT3's street legal that is....
Old 03-23-2015, 07:57 PM
  #7077
Nizer
Nizer's Avatar
Well that was a given, no?
Old 03-23-2015, 08:17 PM
  #7078
Mech33
Mech33's Avatar
They changed the final drive ratio to cancel out the wheel diameter change, so net gearing is almost identical to the regular GT3.
Old 03-23-2015, 08:19 PM
  #7079
Mech33
Mech33's Avatar
Originally Posted by 9972RS
Looks like a 4x4
Yeah... not feeling that.
Old 03-23-2015, 08:38 PM
  #7080
NateOZ
NateOZ's Avatar
Raking the chassis adds downforce by allowing less air to pass under the front and escape out the rear - it creates a vacuum effect.
Here's a pict of an RB9 that shows the rake they used on some tracks for what was a very successful F1 car.
Quick Reply: Consolidated 991RS thread
