991.1 Engine Warranty Question re Track Mods
I’ve tried to read every thread I can find on this issue. But I couldn’t find an answer to my one question:
What modifications void the 10-year warranty?
My car is currently stock. I’d like to make a few mods for track use:
Springs
Drop links
Control arms
Tension arm
Side muffler delete (to reduce heat on rear tires)
Roll bar
AP rotors to replace PCCBs
That’s pretty much it. Nothing crazy.
With these mods, will Porsche honor the engine warranty if/when the FF issue arises?
Springs
Drop links
Control arms
Tension arm
Roll bar
The only thing I can see them fuss about are the side muffler deltes. I would not do them to be honest unless you are going with the Dundon setup with their street headers. Removing them will reduce low end torque and you will feel it. Everything else is suspension related and won't affect your engine warranty.
Porsche-Suchtig (02-07-2021)
Springs
Drop links
Control arms
Tension arm
Roll bar
Springs
Drop links
Control arms
Tension arm
Roll bar
The following 3 users liked this post by GrantG:
On the low end torque issue, are the valved side deletes also likely to reduce low end torque?
KA 991 GT3 (02-07-2021)
Nobody has ever came out with a definitive list.
Remember, this is free warranty work for the dealership so they're typically on your side. I brought mine in with a sharkwerks bypass, but that was it.
They did ask if I had an ECU flash and that was only to let me know that it would be erased through their diagnostic process but that's it.
I am not too sure, I would call up someone with better experience with these cars. The one I had was with a friend's .1 and when we put the side mufflers back on, his car regained low end grunt and he was able to feel it.
I have a Track nanny valve controller in my car and one of the settings is exhaust valves open all the time. I've never been able to feel any torque difference open or not. The .1s don't have all that much torque below 5K to begin with.
I had all of the things the OP noted and never had an issue with my dealer.
Porsche-Suchtig (02-08-2021)
Other than the exhaust, Do the Springs, Drop links, Control arms, Tension arms affect rear wheel steering? Or does rear wheel steering recalibrate?
That is the question that I would find out before changing things.
You will be fine with those mods. They will not care about suspension stuff at all on a engine issue.
Mods have to be related to the failure.
When I was researching exhaust, it was doing a center muffler delete affects HP and torque. The side deletes are free and you just loose weight, and gain more sound.
I would not be worried about cat back exhaust affecting warranty. Headers and other engine mods are iffy.
As for the side muffler delete I've decided not to do it. From what I've found so far, I don't think it will void the 10-year warranty. But I also have not found any data to support claims made about heat reduction. (Seems logical but how much does it really reduce temps by and for what period of time? Weight reduction, on the other hand, is verifiable. But $1,500+ to reduce weight by 30+ lbs is a little steep. I could just remove the passenger's seat for free on track days.
Premium Sponsor
Sorry to OP for off topic.
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
TPC Racing stats:
sgreer78 (02-10-2021)
