Anybody lowered the 991 GT3 1/2"
I wanted to see if anyone has lowered their 991 GT3 1/2" on factory coil overs? I want the car to sit a bit lower and I have the suspension lifter so I should be fine on clearance. My local Porsche certified shop/tech says it is not a big deal to drop it 1/2" but wanted to check here.
Is a new alignment necessary if only a 1/2" drop.
Thanks!
Thanks!
Keep in mind that the coilovers are adjustable in order to allow for corner balancing. They aren't there to adjust 'stance'. You are likely affecting the handling of the car in an adverse way, if that matters to you.
If you drop it 1/2" you should align the car. As Joe suggested the small change in height available at each corner allows for corner weighting. If you do drop it you might find it useful to look at the corner weights and alignment both before and after.
Thanks!
Thanks!
Yes, I lowered mine just over 1/2" ….its almost at the limit for factory coil overs when you have the front lift. Work performed at P dealer….with an alignment.
Even though its a small drop I love the way it looks now!
*incidentally my car is white with PCCB's as well.
Curious, what did your Porsche dealer charge to lower and align?
Brandon, Do you have any pictures you could post of your car with the drop? Did you stick with factory specs on the alignment? Thanks
TechArt's lift system might be a better solution for it lift's the car higher than the OEM solution. Lowering the car a Half Inch means that the front lift doesn't lift the car half an inch higher than it use to. So one may run into problems with that whole idea.
I didn't ask that specific question regarding the alignment, but I can call my tech if you'd like(?)
Originally Posted by Brandon_
I'm happy to take a few pics this week/weekend...sorry I haven't taken any yet.
Does the car feel as if it bottoms out on bumps and heavy braking or does the car feel the same? I certainly don't want to have adverse effects to the handling of the car.
