991 GT3, GT3RS, GT2RS and 911R 2012-2019
Autostacker Garage Lift - Initial Impressions
Old 09-09-2018, 10:44 PM
SToronto
SToronto's Avatar
Received 1,124 Likes on 733 Posts
Nice! Thanks for sharing this. I found next to nothing when making my decision.
Did you have to bolt to floor? Thickness of your floor?
Old 09-09-2018, 11:06 PM
MEM82
MEM82's Avatar
Nice . How much do these lifts tpically run? Thanks
Old 09-10-2018, 12:01 PM
toddjude
toddjude's Avatar
Thanks for very detailed write up. Not being able to get the lower car further in is what is making me lean towards the bendpak.
Old 09-10-2018, 12:18 PM
cbrett
cbrett's Avatar
thanks guys!
they run $5k shipped.
i dont know if you "have to" bolt to the floor or not. i like the idea of it bolting to the floor given the mechanism of the lift. i don't know the thickness of my floor off of the top of my head.
for what it is worth, this lift comes from bendpak. not sure to what extent they are involved with the design, but they sell/distribute it.
Old 09-10-2018, 01:37 PM
HBdirtbag
HBdirtbag's Avatar
This is a very fitting thread. I've spent the last 2 days looking for more info on this lift as i'm in a spot where I just brought another car home (63 impala) and my 996 Turbo is getting forced outside). Can you tell me the width on the inside of the bottom? Need to make sure I can fit the impala in.
I think i'd be cutting it super close on this. My garage beams are 110" up, the 996 is lowered about 1.5" putting it at about 50"....the impala is 55" stock height but i can lay the frame, i think that puts it at about 51", maybe 52" with it still being moveable.
my next problem is my impala is LONNGGGGGG. not sure i'll be able to get out....
Old 09-10-2018, 01:42 PM
HBdirtbag
HBdirtbag's Avatar
Originally Posted by cbrett
thanks guys!
I read a post saying all the testing they did was without them bolted to the floor. But they recommended bolting to insure the lift doesn't shift when loading.
Old 09-10-2018, 02:01 PM
cbrett
cbrett's Avatar
here are the dimensions. hope it helps.
Old 09-10-2018, 02:18 PM
HBdirtbag
HBdirtbag's Avatar
Hell yea, that is exactly what I sent an email to Bendpak looking for today!
Old 09-10-2018, 07:05 PM
NSD991
NSD991's Avatar
CBrett, please post your impressions of how well your RS fits when you’re able. My Gt3 is ok on my current lift but the rear tires don’t have a lot of margin. If the RS fits fine I may switch to autostacker. Thanks again for this post.
Old 09-10-2018, 08:45 PM
kav1
kav1's Avatar
I considered the same lift for my two car garage. Decided it would be too difficult to get in and out of the vehicle. Settled on a single post American customs lift.
Old 09-10-2018, 09:34 PM
wareaglescott
wareaglescott's Avatar
thanks for all the great info. Very informative thread. Appreciate you taking the time to answer everyones questions!
Old 09-10-2018, 10:00 PM
cbrett
cbrett's Avatar
no problem guys! i'll report back once i get the RS home!
Old 09-11-2018, 07:47 AM
GiuseppeM
GiuseppeM's Avatar
I should have got that too instead of a 4 post, how much was the lift if you don't mind me asking?
SM04 (02-16-2024)
Old 09-11-2018, 09:57 AM
Mussl Kar
Mussl Kar's Avatar
Many thanks! This would be perfect for me if I could drive through the lift. Can you post a pic of the rear connector bar that joins the 2 sides? Is it structural? Or just a cover for the hydraulics? Also looks like there is room/clearance to ramp over it. Height of rear connector?
Thanks.
Old 09-11-2018, 10:10 AM
carguy84
carguy84's Avatar
wow 103" is wider than the Bendpak 4 post 9 series. Did you get the single motor version or the double motor version?
Quick Reply: Autostacker Garage Lift - Initial Impressions
