991 GT3, GT3RS, GT2RS and 911R 2012-2019
garage car lifts
Old 01-15-2018, 10:26 PM
  #121
17bhub
17bhub's Avatar
Location: Where I get the fresh scent of spent Jet Fuel & see Cold Smoke!
jlee504 ^^ - definitely bolt to floor - you can always grind the studs/anchors down to the concrete if you move in the future.
Old 01-15-2018, 10:33 PM
  #122
17bhub
17bhub's Avatar
Originally Posted by dewilmoth
Love those single post lifts. Are there gaps between the ramps to be able to do basic maintenance like fluid changes?
Yes - you can order the lift with or without inserts (gap fillers) between the ramps. They are aluminum diamond plated so pretty light and no bolts required to hold them in place. I ordered with the inserts but they are easily removable just in case one of the cars decides to piddling on the car below.
Old 01-15-2018, 11:12 PM
  #123
Raven 666
Raven 666's Avatar
Originally Posted by Psup4s
Forget the lift.... That storm trooper is the shiiiiit
My security guard
Old 01-16-2018, 05:00 AM
  #124
pmpsch
pmpsch's Avatar
Originally Posted by Alan Smithee
I have one. You can get a 991 GT3 under it, but not on it.
That settles it! Thanks
Old 01-16-2018, 11:09 AM
  #125
GiuseppeM
GiuseppeM's Avatar
I have the HD9 unbolted (I bought the caster kit), the air compressor requirement is really something you need to evaluate because it's pretty annoying. I saw they're selling a bottle now that holds the pressure but from what I understand you have to use the lift often to maintain pressure.
Old 01-16-2018, 10:58 PM
  #126
Dalema
Dalema's Avatar
Tangental question - but has / would anyone with the GT3.2 have measured the exact height of the car? I see it's listed at 50 inches, but so is my Spyder and that car looks lower to me when I line up the tape measure next to it.
Important for me to get an exact measurement, as when I do the math on the autostacker lift - I have only an inch or two to spare!
Old 01-16-2018, 11:29 PM
  #127
porscheflat6
porscheflat6's Avatar
Originally Posted by jlee504
how the hell do you guys keep your garages so clean? where do you store all the kid/family stuff??
The don't have kids...
Old 03-16-2018, 07:12 PM
  #128
Dalema
Dalema's Avatar
Hi - was just about to pull the trigger on the Bendpak ST. I measure the rear wheel track at 74 inches on the GT3 - which looked less than the 76.5 inches max width the specs say - what was the issue that prevented it from fitting?
Also - any ideas on cheapest place to buy a Bendpak and any installer recommendations for Bay Area, CA.
Thanks!
Old 03-16-2018, 07:14 PM
  #129
abiazis
abiazis's Avatar
What is a ballpark price to install a Bendpak system?
Old 03-17-2018, 12:12 AM
  #130
ranger22
ranger22's Avatar
I spent $650, but I have heard as much as $1100.
Stack'em up!
SSTHO (05-31-2021)
Old 03-17-2018, 01:02 AM
  #131
porscheflat6
Stack'em up!
Nice set-up!
Old 03-17-2018, 09:13 AM
  #132
white6speed
white6speed's Avatar
Have you guys seen a lift that will work in a garage with a 108" ceiling height that would hold 2 911's each about 50 1/2 inches tall.
Old 03-23-2018, 08:53 PM
  #133
Dalema
Dalema's Avatar
Originally Posted by Jpacione
The HD-9 has an optional air tank that looks like a shock. Mounts under the rails so invisible. It uses the pressure from raising the lift and fills itself. As long as you use the lift somewhat regularly you don't need a compressor. I've had mine for over a year and haven't had any issues. Left the car alone for winter and didn't lose any pressure in the tank either.
Originally Posted by Just in time
I also has the optional air tank installed on my BendPak HD9. So far it has worked nicely. I have noticed though that the lift has to get pretty high up so that it can build enough internal pressure. I have 10+ ft ceiling and my cars get pretty close to it, otherwise pressure stays on the low side. Never have had a problem though and have left my car there for over two weeks at a time.
With regards to the optional air tank (instead of air compressor) - I just talked to BendPak while ordering and she said she wasn't aware of it. Do they still offer them, and what would be the advantage over a cheap compressor - I was planning on using the air tank if tidier.
I've increased the garage door rails, so just need the lift to be delivered and installed now. Had to go with the HD9-ST to get it to fit - so really hope the GT3 or Spyder will fit!
Old 03-23-2018, 09:12 PM
  #134
tgibrit
tgibrit's Avatar
It was $850 for me, including pick up at the local freight depot.
FYI, for those considering the RJ45 rolling jack it will not clear the air deflectors by the front wheels even with FAL, its very close but does not quite clear.
Old 03-24-2018, 07:10 AM
  #135
Just in time
Just in time's Avatar
$750 for the Installation. Asa far as I know the air bottle is still sold.
Quick Reply: garage car lifts
