garage car lifts
#46
Originally Posted by G55amg
Hey guys
I'm also planning on installing a lift I like the Bendpak HD 9.
I will be storing a 964 and a GT3.
I have 10'4" ceilings, do you guys think I have enough space?
Thank you
JV
Thank you
JV
#48
The air bottle is optional. It is like $200. My installer plugged the thing in when the lift was put in place. Rather simple.
#49
I have just over 10ft and have no issues. HOWEVER, I have a P car on it and not have much headroom left. The air bottle needs the lift to go fairly high up to build pressure.
#50
#51
Thank you
#52
I have almost 11' and I can only fit a sedan/sport car underneath because of the garage door rails, so take that into consideration, and I do have the "high lift" motors/rails.
#53
Anyone have a 4-post parking lift in their garage with a ceiling of only 9' or so?
I'm aware of having to raise the garage door rails to its maximum roll-up height to open/close.
My garage ceiling is 9' 6" (or 114")... the GT4 can be on the bottom so what's the max car height I can do for the top ramp?
Would love to also fit the GT350 there... but if not then that means I "have" to buy another car that's lower height. Maybe a .2 GT3 perhaps.
#54
#55
The HD-9 has an optional air tank that looks like a shock. Mounts under the rails so invisible. It uses the pressure from raising the lift and fills itself. As long as you use the lift somewhat regularly you don't need a compressor. I've had mine for over a year and haven't had any issues. Left the car alone for winter and didn't lose any pressure in the tank either.
#56
#57
Any engineers in the group? I have a 10' ceiling but an 18" LVL (or four) running left to right dead center to hold up a couple bedrooms apparently. Possible to tear out the ceiling and move that into the actual joist area of the floor to achieve the same effect and have enough clearance for a lift?
#58
I had 100" and raised my ceiling of part of my garage by 16". Don't ask me what that costs.
#59
Don't ask because you don't know or because you don't want to remember? ;-)
#60
For the guys here that have high rise doors, how close are the rails to the ceiling? Mine are 12" which seems a lot, when I asked the installer he told me he needed clearance for the spring tool...
