Front light rock chips
My front lights have many many chips due to driving close to people in front of me on dirty track roads...
What to do? Looked for a new lens, but you can only buy the whole housing.
Can I polish the light?
Same here, nothing can be done other than new lenses. Someone needs to make track shields for light assemblies as mine get hammered. At this point my lights look like I driven directly behind the rear wheels of a 18 wheeler for all 2500 track miles
Have you used it? A guy at track with GT3 used a "repair kit" (don't know if it was 3M) to remedy the chips and it caused his lens assemblies to delaminate shortly after use so he had to replace both of them?
The UV coating which also happens to be the gloss on the lenses is very thin. Any sort of polishing that layer down has the potential to cause more damage than you're trying to fix
LED headlight housings are ALOT more expensive to replace than the PDLS's.
My headlights look like they have been used for 2 years although my car has 2400 miles on it only...
I was told not to put a film on the headlights like I did for the rest of my car due to delamination.
Can someone please tell me what delamination is and why it would make more damage if I use the polishing kit to the lights.
Its driving me nuts.
My whole car is wrapped, including the lights. When I came to the delamination issue, where the factory UV film cracks and leaves a bad surface when clear bra film is removed in the future, I had a decision to make. I saw another GT3 that didn't have it's lenses wrapped and a big chip in that one made my decision to wrap. My clear bra man, Moe with GP, also indicated when the film needs to be pulled, that the delamination of the UV coating can be removed by polishing and a new wrap, with UV coating can be reapplied.
Judging from what you have, I'd suggest going to a very reputable body shop guy, ask if he thinks he can polish it out and what guarantee he's willing to offer to stand behind his workmanship given the healights are $4k to replace. If you can get somekind of guarantee, I'd get the chips buffed out and I'd wrap thereafter. Hope that helps.
Dan (is very happy the car is bubble wrapped)
My whole car is wrapped, including the lights. When I came to the delamination issue, where the factory UV film cracks and leaves a bad surface when clear bra film is removed in the future, I had a decision to make. I saw another GT3 that didn't have it's lenses wrapped and a big chip in that one made my decision to wrap. My clear bra man, Moe with GP, also indicated when the film needs to be pulled, that the delamination of the UV coating can be removed by polishing and a new wrap, with UV coating can be reapplied. Judging from what you have, I'd suggest going to a very reputable body shop guy, ask if he thinks he can polish it out and what guarantee he's willing to offer to stand behind his workmanship given the healights are $4k to replace. If you can get somekind of guarantee, I'd get the chips buffed out and I'd wrap thereafter. Hope that helps. Dan (is very happy the car is bubble wrapped)
I still think they've been cleaned with an ammonia containing product (like windex) that's started to pull the UV coating off - mine were perfect unwrapped after 2000 miles, including winter driving behind some salt trucks etc when I got caught in a snow storm. It's still going to feel like they're pitted as it is corroding the coating.
https://rennlist.com/forums/991-gt3-...l#post11727194
In that thread, I was planning to keep the film off and it was only later in time when I changed my mind and decided the film was necessary. By the way, to OP, while doing a search for the above, I noted this:
https://rennlist.com/forums/991-gt3-...eadlights.html
Back in June I recommended putting on film at that time. I looks like three months later, it turns out you might have been better off putting on the film as suggested.
Dan (hates to say I told you so but....)
