New German violet coolant.
So I haven’t been driving my car much lately and today for the 2nd time my low coolant light came on and went away quickly in my 2010 base Cayman manual. I HAVE NO VISABLE LEAKS but I went and bought coolant anyway. I could not find my distilled water I’d stored in the garage so I was forced to buy premixed German coolant. A couple surprises happened. I finally found what I needed but it was Prestone, smh. However according to Prestone, Peak and a few other manufacturers of coolant the recommended color for Porsche and other German brands is no longer pink but is now violet/purple. No biggie, I bought the purple premix and went on my way. The 2nd surprise was my car took a whopping 2 QUARTS!! I was like wtf... I put the coolant in and checked for leaks and there were NONE I could see. Took the car on a very long and spirited drive with no complications whatsoever. Car behaved flawlessly per usual. I had not added coolant to my car in 5.5 years so from what I’ve read it is not unusual to need to add coolant much sooner. I assume what was already in my system was the older pink coolant. Was it ok to top off and mix with the newer( and I assume more advanced) violet/purple stuff? EVERYTHING I’ve read (and my car’s performance) has indicated that it is indeed fine but I want to hear from the experts here pls....
I've experienced coolant evaporation in my 981 and have seen several people note the same on Planet-9. I got a low coolant light at about 4yr 50K miles, topped it off with about 1 1/2 qts and have been good to go.
So from my experience, it seems like that is within reason.
PhillyNate (02-11-2021)
Make sure the cap on your coolant system is sealing properly. If it is difficult to remove and/or if there is residue on the sealing surfaces it would probably be a good idea to replace it.
The following 2 users liked this post by TMc993:
ekam (02-12-2021),
+1 on that - I did replace my coolant cap at about the same time. It was warped and very hard to turn. I believe that was a contributor to my coolant loss.
The following 2 users liked this post by ledbette:
ekam (02-12-2021),
Spot on. I ordered a cap today based on some other things I read as well. Thank you everyone for your input.
In a pinch when refilling the coolant system on my track car, I had to use some Peak violet pre mix to finish off the job, added to the concentrate Pentosin (mixed with distilled water) I had run out of.
Also Zerex G40.
No issues.
Also Zerex G40.
No issues.
PhillyNate (02-12-2021)
I think you should completely drain and refill your coolant for complete peace of mind, but that's just me.
Do you know if it's ever been flushed in the past 10-11 years?
The purple stuff is, I believe, G13. The original Porsche pink stuff in 2010 should've been G12+. They are compatible, though there may be some loss of corrosion protection if you can trust the chart here:
https://www.wolflubes.com/EN_EU/Blog...d-coolant.aspx
I got a low coolant warning about a months ago and being unable to check the coolant level yourself (Thanks Porsche!), I took it to my mechanic and got it topped up as it lost 1.5qt.
I just checked my cap and there's white residue AND the cap part # ends in .00 - not good.
New cap is ordered and I should be able to find out mid next week which version they currently have.
On the 987 there are plastic min and max "plates" inside the filler neck, and there's a dipstick on the 981.
Received 1,160 Likes
While it might be nice to completely drain the system and flush it then drain it again and refill it - the reality of this is - it's rarely going to happen unless some leaks or damage occurs at the front end of the car where the radiators live. Even then, I might expect the majority of coolant to be removed, but I doubt if many shops would consider refilling the system with distilled water, then running it, then again draining it yet again and refilling it with new coolant and distilled water. I think the labor cost would make this impractical. But that's just my opinion for whatever it's worth - some fanatic might have done this at some time - more power to them.
PhillyNate (02-13-2021)
I don’t unfortunately. Worse is at 68k miles I’m on the original water pump and know full well I’m on barrowed time.
No Don: G40 is just BASFs name for their G12++ product.
G12, G12+, G12++, and G13 are all supposed to be backwards compatible to a reasonable extent. They're all VW/Audi specs. FCP Euro has a similar table (though the colors seem to be wrong, G12+ and G12++ are very often pink in my experience).
https://blog.fcpeuro.com/how-to-pick...t-for-your-car
I do have chalky residue on the trunk cap but can’t gauge if that is enough to explain the amount of loss. Will instal when I receive and continue to monitor.
Whenever you find white residue buildup on the cap is always a sign that someone in the past has filled the cooling system with tap water. I found even dealers rarely use distill water to top up the system. The dealer did it once and I gave them a earful afterwards because once they use tap water, the system will forever be contaminated unless you do a complete flush.
