"Upgraded" Steering Feel?
#256
#257
I have been doing both with engine running. But you can do it with the car engine off and on a 40amp charger to be safe. But honestly the coding is so fast that the battery should be fine. It’s not long like a tune that writes to the ECU. The coding for what I have changed has never taken more than 5 seconds. But god forbid it went dead at that exact moment, who knows what would.happen. Don’t want to brick an ecu so use a charger or keep the car on.
You don't want to experience what I did. Learn from my mistake! Use a charger with a power supply. Not all charges have this function. Porsche recommends 40 amps, I think for lots of safety overhead. Some have been very successful with 15 amps. I have a 25 amp unit, which with a full battery, works fine for my needs. A 40 amp power supply is expensive. You may get away without using one, but you won't be happy if you don't. I would guess if the engine is running, you are probably ok, but don't think all coding can be done with the engine running.
#258
I would like to add to the above caution. He isn't kidding. I have done many coding and tune changes without a charger, before I knew I should be using one. I had no problems. But one day I was loading a tune with a fully charged battery (this takes several minutes, not a quick 5 second code) and car went into a power shutdown as it recognized a low power condition. What happened after was very unsettling. Tons of errors, beeps, clicks, no start, disturbing messages regarding the ECU. I thought for sure I bricked the ECU. Luckily, the FVD tool I was using for the tune install had a recovery function, and upon running it, all was sorted.
#259
Just adding an additional data point. I typically do the EPS and PTV coding for people with the engine running at idle for that extra peace of mind.
#260
This is all great information! Generally, when I try to code any car I hook it up to a battery charger. I did not even know that our cars would allow coding changes while the engine was on and idling. I still have not changed the EPS software on my '16 Spyder- I forgot during the service last fall. I can hardly wait to get the car out of winter storage to try this! Thanks everyone.
#261
#262
That's correct. I've performed the calibration procedure 3 times (twice on my car and once on a friend's) and didn't need a charger at any point.
#264
There will be no issues with his?
#265
My concern here is that if I look at Jeff's PDK Recalibration video, PIWIS 2 instructions say that you have to be connected to a charger https://www.youtube.com/watch?v=E3qRHUIuR2E but if I do this in my multi-owner underground garage with car engine running for 20 mins connected to a mains electric supported battery power supply, one of my neighbors will likely call the police or I will asphyxiate myself, so I would love to do this in a remote outside car park with my fully charged laptop.
#266
is there any way to revert the upgrade back to default? I don't want it to revert to default factory but I am worried that my PDK service at the dealer will somehow revert it back to normal if/when they disconnect the battery.
#267
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1227/dscf0641_jpg_70d5c7b5fed82228cd252eab367053faf2cb64ed.jpg)
Added another member to the GT3 steering
![Group Hug](https://rennlist.com/forums/images/smilies/grouphug.gif)
Richard. (02-26-2024)
#269
