What did you do with your 981 today?
#721
When I installed the brace on my 981CS I used a right angle drill from the top with a short broken bit to make a pilot hole then used a step bit from below to make a larger hole for two hardware store purchased bolts. I didn’t want to remove the support panel to drill the hole as it may require an alignment of the rear suspension and replacement of some of the bolts that are torque to yield bolts. The newer pans for the 718’s have the holes but it is easier and cheaper to drill the two holes in the existing panel.
Jim
Drilled holes in existing panel
Jim
Jim981CS (08-12-2022)
The following 4 users liked this post by WV997S:
The following 2 users liked this post by Akahny:
forestial (08-22-2022),
Kernel Klink (08-22-2022)
#725
#728
TBotD was a bit underwhelming for me honestly, especially since you have to monitor opposing traffic diligently. Evidently no one pays lane discipline any mind lo.
Did you happen to make it over to KY and hit the Slayer or Appalachian Autobahn? Great roads!
GZ Boxster (09-05-2022)
#730
https://www.backofthedragon.com/
#731
It's a road from Marion, VA to Tazwell, VA. There are a number of Dragon roads in the Appalachian-ish region. Head, Back, Tail. There may be more, iirc. It's been around for years, but recently they modeled it after the ToD with photographers and whatnot. They did add a brewery at the store, which is nice, but not a great mix with spirited driving lol.
#732
Went to the Checkeditout Chicago car show yesterday. https://checkeditout.cc/ Almost 350 cars were featured at this exclusively Porsche event. Everything from a 914 to a 918, there's something for everyone here. This is put together by a fellow RL member every year as a local charity fundraiser. Good time spent with many, many local Porschephiles. Here's a few highlights.
The following 4 users liked this post by Prairiedawg:
#734
Replaced mine and buddy's headlight lenses. I have a Cayman S so I also did black out mod on my trim like on the GTS and GT4. His is a GTS so it's already painted black.
Before
Before
After
Before
After
Finished product
Before
Before
After
Before
After
Finished product
The following 6 users liked this post by chase15:
colnagoG60 (09-03-2022),
KBell (09-04-2022),
Kevin CS (09-04-2022),
nhnguy12 (09-04-2022),
Randy_B (09-07-2022),
and 1 others liked this post.
