Alternator removal DIY
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Not very often do I ask for help but my alternator is about ready for an overhaul (not charging at full capacity) do any of you as a link to a DIY for removing it.Do I need to remove any parts from the top in the engine bay or can I get at it from the bottom.TIA
I changed my alternator out many moons ago. IIRC, I was able to remove it from the bottom with little hassle. I can't remember if I took the air box off or not (or if I had any other parts out of the car at the time).
You should make 100% certain if it's your alternator. I have found the ground cable from the starter to the alternator to be a cuprit at times. Since the alternator sits right below the throttle body (coolant runs thru it) at times, a coolant leak can cause corrosion to the alternator leads.
Due to the 968 inta manifold design, I would think pulling it from the bottomw might be easier. Your other choice would be to seperate the throttle body, which would require new O'ring gasket.
You may need a "puller" to remove the pulley off the alternator. There is also a channel key, a small piece of metal that sits in the channel of the shaft and pulley itself. It's small and easily misplaced. I used jack stands at a height were I had access from top and bottom. Best of luck with the repair
I replaced mine recently and it was fairly easy. Pulled it out from the the top. Forgot what I removed to get better access, maybe the throttle body. It is heavy and annoying to get lined up with the bolt holes.
Just remember to disconnect the battery first or you could get a nasty short with lots of sparks.
Belt is not slipping but there is a sligth noise coming from the alternator bearing so that why I'm going with a full rebuilt.I trust the woman doing the rebuilt (husband has pass away but she kept the shop going) has done both my 944 alternator /starter in the pass & there is no issues with them up to date so I trust her work.First the rebuilt price is what I consider decent ( full rebuilt including brushes/regulator) $175.00 CDN plus no shipping hassle it's only five minutes from my place.
Just did mine last fall as part of putting the IceShark cables in. I got it out the top after removing the MAF, and yes there was blood and tears getting it back *in*. Those !@$# holes would not line up for anything.
Yep, I had the same experience. For some reason, gettng those stupid holes to line up is a major pain.
Hi, I'm wondering if your 968 benefited from the IceShark cables? I had a set on my former 951 and I so wish I kept those cables.
