View Poll Results: Fix the 968 or part it out??
It's worth it!! Fix it!!!
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
4
22.22%
Not worth it!! Part it out!!
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
14
77.78%
Voters: 18. You may not vote on this poll
1992 968 - project or parts car?
#33
Hey everyone,
By now most of you know the car is well on its way to the recycler and has helped many other 968's by donating it's organs around the US. I have had several people interested in parts from the engine but not the whole enchilada so I wanted to put it out there 1 more time before I pull it apart.
The engine is still in the car along with the suspension and brakes which will all be removed very soon but is not included in the list below, otherwise much of the car is gone (see pic). If you need as obsure item which may not be listed such as parts of the A/C blower system etc. I may still have it.
Engine - 3 Liter DOHC Vario~ approx 90K $2,400.00
Transmission 6 speed no LSD approx 90K w/ axles $1,300.00
Transmission 6 speed no LSD - broken down, needs repair $500.00
Batwing $200.00
Lower Engine Cover $50.00
Drivers Headlight Assembly $250.00
Hood, straight but has some dents $200.00
Passenger Side Door w/ windows, handle - no mirror $400.00
Rear Trunk Lid - Straight? $50.00
Spare Wheel $100.00
Steering Wheel w/Airbag $150.00
Radiator $40.00
Climate Control Unit $150.00
Cooling Fans with shroud $100.00
Owners Manuals $75.00
Rear Seat Backs with pull cables $50.00
Sun Visors $50.00
ABS Control Unit $150.00
Alarm Control Unit $50.00
Cruise control unit $75.00
Shifter console trim piece with boot and **** $50.00
Convertible Top Motors (Not tested due to broken roof bow, PM w/questions)) $150.00
Convertible Top Transmissions/cables (Not tested due to broken roof bow, PM w/questions) $400.00
Batwing $200.00
Spare Wheel $100.00
Radiator $40.00
Sun Visors $50.00
#35
The batwing is in very good shape. The three tabs that hold it to the plastic cover are all there but I believe one of the holes is cracked but could easily be fixed with some epoxy which I was planning to do once I get it cleaned up. Engine belly pan is in very good shape as well with no defects I am aware of. I will inspect both items more closely tomorrow and let you know for sure.
Thanks!
J
Thanks!
J
#37
Hey Guys,
Yes the batwing is in good shape with only minor problems. i'll get pics and put them up tonight.
The passenger door is on good shape, the door panels have been sold but comes with both pieces of glass, window regulator etc. i'll get a pic when I go back to the shop today and post it tonight for you.
THANKS!
J
THANKS!
J
