968 Forum 1992-1995
Where is the cabin filter?
Old 09-17-2008, 08:58 PM
Neverendz
Neverendz's Avatar
Default Where is the cabin filter?
I was reading the owners manual and it has scheduled replacement for the cabin filter. I seriously doubt if mine has ever been changed. I also have noticed low airflow from the vents. Where the heck is said cabin filter???
Thanks in advance!
, Bill
Old 09-17-2008, 09:59 PM
RajDatta
RajDatta's Avatar
Look under the blk plastic cover that goes between the lower windshield and firewall. Its a big plastic piece that covers the entire center section. Pull it off from the sides and you will see the cabin filters. There is one on each side.
Raj
Old 09-17-2008, 11:31 PM
StewHatch
StewHatch's Avatar
Can I remove these and benefit from unrestricted airflow into the cabin? Am I wrong to assume that I don't need these filters?
Old 09-18-2008, 09:13 AM
Neverendz
Neverendz's Avatar
Thanks Raj.
Cabin filters are nice if you have allergies. They also help keep the ductwork clean. That's about it.
Thanks again.
, Bill
Old 09-18-2008, 09:36 AM
RajDatta
RajDatta's Avatar
NP Bill.
Stew, you wouldn't want your engine to injest dirty air, that is why you put in an air filter. Why not treat yourself to the same luxury? j/k
Raj
Old 09-18-2008, 12:37 PM
Neverendz
Neverendz's Avatar
Good point!
Do the 944's have cabin filters?
, Bill
Old 09-18-2008, 01:01 PM
kwikt
kwikt's Avatar
What about the 92 968? My 968 don't have the cabin filters. And the 94 filters will not fit. I hope it's not a dealer only item.
Kevin
Old 09-18-2008, 01:12 PM
RajDatta
RajDatta's Avatar
The early cars did not have cabin filter. This was one of those 94 and later car deals. Most manufacturers around taht time went to cabin filter setup.
Raj
Old 09-18-2008, 06:31 PM
Neverendz
Neverendz's Avatar
I took out the cabin filters. Clogged solid! I had less than half of the airflow I have now! I'm thinking that this is a Porsche only part. I'll post some part #'s and prices when I find out.
Thanks again Raj! I should have done this before summer!
Sometimes it's just the little things that make one happy.....
, Bill
Old 09-18-2008, 06:41 PM
Jfrahm
Jfrahm's Avatar
I made some for an old 89 S2 I had by wiring some cut-to-fit furnace filter over the grilles. I was not after pollen filtration so much as keeping leaves and crap out of my ductwork. On the cabrios I have not made the effort (plus I no longer park outside.) I used a piece of electrostatic furnace filter.
-Joel.
Old 09-18-2008, 09:29 PM
Neverendz
Neverendz's Avatar
$36.95 for a pair of Mahle cabin filters on partsgeek.com.
, Bill
Old 09-18-2008, 10:27 PM
RajDatta
RajDatta's Avatar
Excellent price.
BTW, I have a newer style cabin filter housing if someone wants to retrofit this. I thought I had thrown it out but when I was checking thru some stuff for Steve, I saw that I still have the upper cover with the filter openings.
Raj
Old 09-19-2008, 05:24 AM
FRporscheman
FRporscheman's Avatar
Ghetto fix of the day: Smack the cabin filter upside down against the floor to kick out most of the dust/dirt/debris, then shop vac it, then a few hits through the backside with compressed air, good as new! Well not really but it does make a difference.
On a more productive note, I've heard a light spraying of some kind of antibacterial stuff can help a lot, like Lysol or whatever.
Old 09-19-2008, 09:25 AM
Damian in NJ
Damian in NJ's Avatar
Don't some people use K&N filter cleaner?
Old 09-19-2008, 09:46 AM
Neverendz
Neverendz's Avatar
Arash, I tried. But mine were too far gone. But I plan on cleaning them regularly like that. Like every oil change.
, Bill
Quick Reply: Where is the cabin filter?
