WTB: Cup 1 wheels (OE silver)
I think the mistake you are making is thinking that he said OEM 968 wheels. He just said OEM, meaning original Porsche wheels. He never mentioned OEM 968 wheels, did he?
Your buddy said the exact same thing I said earlier.
Raj
Raj
I'm not sure if CUP I or not, they are NOT boxster wheels and came on my car from the factory
That part is obviously incorrect. My response was in particular to your quote about them being OEM 968wheels. Those wheels came on 996's and Boxster.
So, I went back and read the complete description instead of just reading your quote and yes, he did say they came as original wheels on his 968, which is incorrect.
You were right in assuming that he was suggesting them to be on his 968 as originals.
Raj
Raj
...So, nobody likes the idea of calling them the "jelly donut wheel?" I sure like jelly donuts.
The one's I picked up have some bad scratches on the faces and 2 small areas of curb rash. Has anyone found a good DIY paint/clear that is tough enough to stand up to the rim clamp machines?
I just painted my new wheels, and cleaned up some marks from laying them upside down on a brick driveway (PO).
First, I sanded the wheels down with 1000 grit, then I used Bondo glaze on the nicks, let it dry for 4 hours, sanded the bondo down with 400 grit, then 600 grit. Wiped them down with a tack cloth, used some duplicolor self etching primer, then sanded the primer with 3k grit paper. Wiped them down, then sprayed them with Duplicolor graphite (silver is available) 2 coats, then wetsanded that with 3k paper, then 2 coats with duplicolor clear, and I've been very happy with the results.
My short DIY...Raj has seen them in person and can comment on the outcome, I think they came out pretty good!
Steve
Steve
Did you use the Duplicolor "Wheel Paint" that they sell, or just regular duplicolor?
Have you have tires mounted since the repaint and did they fare ok against the machine, road debris, etc?
mmmmm.... jelly donuts
I bought a set of 993 Cup wheels (hence my fascination with the names - just went through this ad nauseum) last fall and puzzled over the cheap v. expensive refurbishment question. The wheels were in good condition and roughly fit your description - a few chips and a little curb rash. As my car is a daily driver perfect is not a requirement. If you want perfect then professional refinishing, at around $100-150 per wheel, is the best option. There are probably several shops in your area that provide this and some will come to you and do the work on site without even having to demount the tires.
You can also sand, bondo, and paint them yourself. 968Forums has a detailed DIY and I suspect Rennlist does as well.
I chose a cheaper route as I decided that my investment in bigger wheels/tires was already approaching $1,000 - and all of this just because I wanted bigger wheels (always have to keep the bookkeeper/spouse from killing me). I bought the correct Wurth silver alloy spray paint and, spraying some in a small cup, used a detail paint brush to apply multiple coats of paint to fill in the chips and slight rash. I then sprayed just a bit of Wurth clearcoat to give the repairs a bit of hardness. Will it survive contact with metal? Probably not.
This process produced a wheel that passes the '5 foot' test with flying colors. The Wurth paint was a perfect match. They look great, until you stick your nose in them and then you see the trace outlines of the repairs.
I went the proffesional route. Those coming to Hershey can see the results which i was happy with. the nice thing was the refinisher was able to bake the wheels in an oven after they were painted for stronger adhesion. My tires were removed and the remounted by the restorer who used the sticky weights properly mounted behind the wheel faces. He also straightened and cleaned up the rear of the wheels. This process cost me $150 per wheel. They came out nice.
Jeff, that is an excellent price. I wonder how much they would charge for 3 piece wheels. I can't wait to see them in person. If they look great, I might have a project for them.
I spent close to $1500 to get a set of 3 piece wheels redone.
Raj
Raj
Steve
Steve
Raj
He does them all. I saw some crazy 20" BMW m-series wheels that he was working on with so many spokes I couldn't believe it. He's located in Wallingford, right off the merritt parkway. He fixes the wheels and does the mounting. He has another guy do the painting for him.
Jeff
