DIY - Camshaft chain, tensioner pads
This DIY will walk you through the removal and replacement of your cam chain and cam chain tensioner pads. This procedure is designed for the 968 owner but most of the steps should be applicable to the 16v 944S and 944S2. We recommend doing a complete timing belt, waterpump, and front oil seal job while doing this, if they have not been done recently. This article will assume you are not doing any of those though, so please cross-reference a belt write-up and do those steps when appropriate. There are a few aspects of the job that make it complicated. These include the need to:
- slacken and partially remove the timing belt
- re-time the cams
Here is a list of all of the parts that you will need to get, with quantities in parentheses:
(13) 928 104 115 02 ....... rubber donut seal for valve cover bolts
(1) 999 701 693 40 ........ o-ring for variocam actuator poking through valve cover
(1) 944 104 463 02 ........ gasket for variocam actuator poking through valve cover
(1) 928 104 447 09 ........ valve cover gasket
(4) 928 104 443 08 ........ spark plug hole sealing rings
(2) 900 123 050 30 ........ crush washers for variocam oil tube
(1) 999 701 844 40 ........ o-ring for variocam oil tube
(1) 944 105 501 05 ........ cam chain
(2) 944 105 509 00 ........ cam tensioner pads
(1) 900 117 073 00 ........ woodruff key for exhaust cam (optional)
(1) 999 510 022 08 ........ main triple-square bolt (cheesehead) for cam sprocket (optional)
(1) 999 113 282 40 ........ exhaust cam seal
(1) 928 105 215 00......... seal cap at front of head
(20) 999 510 029 02 ....... m8x40 triple-square (cheesehead) cam carrier bolts (optional) (or m8x40 stainless steel allen bolts & washers from a hardware store)
(1) Some Loctite 574
Here is a list of special tools you will need before beginning:
Porsche Specific Tools (recommended, but can proceed without):
If at any point you come across a fastener that you have difficulty with, don't go straight for brute force. Try a little penetrating oil, and try the "bolt wake-up" technique, where you use a hammer and drift to smack the head of the bolt, in order to break the seizure. Never bang a hammer on the end of a wrench. If you need more strength, use a pipe or cheater bar for more leverage.
You will need to undo the timing belt from the camshaft sprocket. It is not necessary to do a complete R&R of the belt - you can just slip the belt off of the cam sprocket and slip it back on later. See the Workshop Manual or Clark's Garage for the full belt replacement procedures. A complete belt job will also entail a whole new list of parts that you'll need.
1. You must depressurize your fuel rail before beginning. Take out your fuel pump fuse (or your DME relay) and try to start your car. It will probably start for a moment, then shut off. Crank it a few more times, and this will deplete most of the fuel that was in the rail.
*Another way to depressurize is to let it sit for some time.
2. Disconnect the battery negative terminal.
3. If equipped, remove the front and rear plastic engine bay covers, and the plastic belly pan.
4. Remove the entire airbox assembly by disconnecting the 4 10mm bolts on the side of the crossmember, the 2 clasps that hold the MAF to the airbox and the front 10mm bolt holding the airbox to the body. By removing these connections, you can pull the entire airbox as a complete unit.
5. Set the engine to TDC on cylinder 1. You can use the mark on the cam sprocket and line it up against the mark on the rear sprocket cover, or for more accuracy, you can use the mark on the forward surface of the flywheel (on the "back" of the flywheel, seen from under the engine, looking from the front of the car toward the back of the car).
6. Remove the starter, leaving it connected, and tie it out of the way. Lock the engine at TDC using the flywheel lock 9206/1. It is recommended to install a flywheel lock once you have your engine at TDC, but can be done without it if you're careful not to move the crankshaft.
7. Disconnect the coil wire from the distributor cap.
8. Using a screwdriver or socket wrench, undo the 3 captive screws holding on the distributor cap.
9. Pull the cap away and lay it somewhere, with the plug wires still attached.
10. Undo the 3 captive allen head bolts holding on the distributor rotor, and remove the rotor. The bolts will stay in the rotor. Don't lose the 3 little aluminum spacers.
Note: If you will NOT be setting the cam timing, and wish to preserve your current cam timing, you must now put 3 spare bolts (M5x15) and washers into the holes where the distributor rotor bolts go. These bolts will lock the cam sprocket's orientation, and preserve your current timing.
11. Remove the power steering belt by loosening the 2 lock nuts on the turnbuckle and turning the turnbuckle to loosen the belt.
12. Remove the alternator belt the same way that you removed the power steering belt, but also loosen the bolts at the front and rear of the AC compressor pivots.
13. Remove the 9 10mm bolts on the timing belt cover, and remove the cover (both parts together, or separate).
14. Undo the 3 10mm bolts on the metal cam sprocket cover, and use a screwdriver to gently pry it off. It's magnesium, so be gentle.
15. If you didn't use a flywheel lock, you must do this step. Place a wood block on the passenger fender inner channel (where all the fender bolts are), and put a large crescent wrench on the hexagonal washer which is right in front of the cam sprocket, positioning the crescent wrench so it is as close to the wood blocks as possible, and stack up some more wood if needed. The idea is that the wood blocks will push against the wrench for you. This hexagonal washer allows you to counter-hold the cam while you undo that big cheesehead bolt in the center. It is OK if you move the cam a few degrees either way.
*You can also put the crescent wrench on the cam itself - there are hexagonal sections for this - you need to pop off the valve cover to see them.
16. Using a 10mm cheesehead tool, no extensions, and either a breaker bar cheater pipe, undo the main cam cheesehead bolt. Be sure to hold the tool as straight as possible. If the bolt strips, which it often does, you will have to drill, grind, etc, and it is hardened. The torque spec on this bolt is 48-52 ftlb.
17. Loosen the nut on the balance shaft belt tensioner, release the tension, and move the top-right portion of the belt down and away.
18. Remove the two 13mm nuts retaining the hydraulic belt tensioner.
19. Remove the circlip on the base of the timing belt tensioning lever.
20. Pivot the hydraulic tensioner so it points more towards the engine, while pulling the tensioner lever away from the engine. Once the hydraulic tensioner's piston clears the lever, there will be no more pressure on the lever. Now you can work the lever off of the engine. The lever's pulley has a lip on the back side, so you'll have to get some slack on the belt to get it past the lip.
*Another way: take out the timing belt idler roller, and put the bolt back in with a spacer on it. Use a hook-shaped pry bar to pry between the spacer and the tensioner lever. Do this enough to slip the belt off of the cam gear. It will take muscle and two people (one to wrestle the pry bar, one to slip the belt off). This way the lever can stay on.
21. Remove the hydraulic tensioner.
22. Finally, slip the timing belt off from the cam sprocket.
23. Tuck the belt away somewhere, and don't kink it. Use zip-ties, bungee cord, etc if you need to.
24. Pull off the cam sprocket, zinc-plated shield, and the 3-spoked hall effect inducer. A little penetrating oil helps loosen things. Spray some PB Blaster or such around the cam hole.
25. Unplug the Hall sensor. The plastic on the connector gets brittle over time so be very gentle or else the connector will crumble into pieces. It costs over $100 to replace. At this point, if yours is original, it likely needs to be replaced anyway and now is the perfect opportunity.
26. Remove the rear metal cam sprocket cover. (3 10mm bolts)
27. Remove the woodruff key. Wire cutters work for this, but they will leave marks that you may have to file down. Pictured is an 8v, but same idea.
28. Remove the fuel rail vanity cover (the metal cover that has PORSCHE on it). It is secured by 4 M4 allen head bolts.
29. Pull out the spark plug wires from the head, and lay them somewhere out of the way, like over the intake manifold.
30. Undo the 2 fuel lines from the rail. You will need to use 2 wrenches per line, one wrench to turn the nut, one wrench to counter-hold the fitting on the fuel rail. This is very important, because if you don't counter-hold the fittings they will bend and possibly break. If you are planning to remove the rail for other purposes, now is the time (and you can just remove the rail along with these two hoses).
31. With the two fuel lines disconnected, you can tuck them out of the way, like behind the engine hoisting eye.
32. Unplug the VarioCam wire from the head and put it somewhere out of the way. You can tuck it under something; I used a zip-tie to hold it to the cruise control cable, over the intake.
Note, in the above picture, I have disconnected the cruise control cable and have swung it away from the valve cover. You can leave the cruise control cable connected.
33. Undo the 13 allen head bolts holding on the valve cover. When taking them out, note where each bolt came from, because there are 2 different lengths, so it's important to put the bolts back in the correct holes. What I did was take a piece of cardboard and draw dots mirroring the arrangement of bolts on the valve cover. Then I punched out the dots. Each time I removed a bolt, I simply put it into my cardboard "bolt palette". The rubber donut seals on these bolts must be replaced. The torque spec on these is 7 ftlb.
34. Remove the two small allen bolts next to the VarioCam actuator. Gently pry off the aluminum collar. The o-ring inside this collar must be replaced, as well as the gasket that sits directly under the collar.
Note: This is not needed if you are not changing the gasket and seal.
35. Lift off the valve cover and maneuver it away from under the cruise control cable.
36. With a magnet in one hand, and an allen tool in the other, remove the VarioCam oil tube's banjo bolt (#1 in the picture), and be careful not to drop the bolt, or the TWO washers. One washer is below the tube, one above. The washers are copper or aluminum so they will not be caught by the magnet so be careful.
Next remove the 2 bolts holding the other end of the oil tube (#2 in the picture). One of these bolts is really long. Now GENTLY remove the oil tube. This tube is very expensive. Now the oil inlet of the VarioCam tensioner is exposed, and there is a little metal ball (with a black metal cuff) sitting in there. It will want to get lost, so be aware and careful with it.
Next remove the 2 bolts on the right (#3 in the picture).
37. Carefully remove the check valve (that metal ball + cuff) from the oil inlet of the VarioCam tensioner. You can use a magnet, with a shop towel over it for cleanliness.
38. You need to undo these 20 bolts.
The front 4 go through one solid piece. The other 16 are in pairs, holding the cam carriers down.
You may end up needing to drill some out. I had to drill out 16 of 20, because my low-quality tool destroyed the bolt heads. I have since bought a much better cheesehead tool.
39. As you take each cam carrier (bearing cap) off, be sure to lay them out properly so you can put each one in the same spot it came from, the same orientation that it was.
Note: bearing caps are machined with the head they come on, so make sure if you have multiple heads or cam carriers, DO NOT mix them. The trick to telling if they are matching is to look in the middle of the head on the exhaust side by the studs. There is a stamp with the matching number.
When removing the front large piece, also take this opportunity to remove the cam seal with ease.
Note: Try to loosen the carrier bolts evenly (all 16 of them) so the valve springs don't pressure the camshafts into bending. Each carrier needs to come off straight, to avoid binding the dowel pin. There is a special tool to help hold things, but being careful and evenly removing the bolts will work too.
This is the special tool. If you have it, install it first as shown, then remove the remaining bearing caps, then remove the tool.
40. Lift the 2 cams + VarioCam out of the head.
41. Position the tensioner into a vice or a very good c-clamp. Apply some light pressure to relieve the pressure on the chain, then slip the cams + chain off of the tensioner. Decompress the tensioner and take it out of the vice.
42. Remove these two posts using an allen tool.
43. Slip the old tensioner pads off, and slip the new pads on.
44. Reinstall the posts into the tensioner. The posts are loctited so make sure you use loctite (medium strength) when you put these back in.
45. Swap the chain on the cams, noting the blue links on both chains, and orienting the new chain just like the old one. The cams should have triangular "arrows" that indicate where the blue chain links should be.
Note: The arrows should be 7 links apart, that's why those blue links are there. Note that not all new chains have blue links!!! So just count 7 links (5 links in between them).
46. Put the VarioCam tensioner in the C-clamp (or vice) using false jaws (towels work) and slowly compress it. If you have special tool 9530, use it now, and you can put away your vice. If not, C-clamps work better, keep the clamp on the VarioCam and have patience. Slip the whole tensioner back into position between the cams and within the chain, then remove the clamp.
Note: I have since made my own version of special tool 9530, which is a bent piece of coat hanger.
Note: I have done this without a clamp as well (just bare hands) in the air. It is possible, but difficult.
47. Put oil or assembly lube on the surfaces of the cams. Position the cams, tensioner, and chain back into the head, at the same cam orientation as before. The blue chain links should be right above each cam.
48. Put oil or lube on the cam carriers. Evenly screw down the carriers, torqued to 15 ftlb. It's impossible to do it perfectly balanced without the special tool but do your best and it will be fine.
If you have special tool 9248: Remove spark plugs from cylinder #1 and #3. Place 9248 Cam Saddle tool on bearings for cylinder #1 and #3 in conjunction with tool 9226 and compress. This will compress the cams evenly. Install bearing caps after lighly applying engine lube to cam bearing carriers for cylinder #2 and #4. Torque them to 15 ftlb.
49. When fitting the front cam carrier piece (the one held by 4 bolts), you must apply a film of loctite 574 to the mating surfaces. Cleaning the old 574 off of the surfaces is optional - the FWSM states that new 574 dissolves old 574, but I clean off as much as I can anyway to not let it be built up too thick.
50. Lightly lube the new cam seal, and install onto the exhaust camshaft, only after the front cam carrier piece is installed.
51. Reinstall the check valve (ball and cuff) into the VarioCam tensioner.
52. Install the tensioner mounting bolts, torqued to 7 ftlb.
53. Reposition the tensioner oil tube, using a new o-ring on the tensioner-side of the tube, and 2 new crush washers on the head-side of the tube. Torque all 3 oil tube bolts to 7 ftlb.
54. At this stage you can wrap everything up (in a reversed manner of disassembly). However, if you want to use the factory method of setting your cam timing, this is the time, with the valve cover still off.
Every part of reassembly is clear except the belt tensioner. It must be compressed in a vice, and locked with a hard metal pin (I used a drill bit) in order to be placed back into position, then the pin is pulled out. Important to note: There is a "special tool" that MUST be placed on the back end of the tensioner before you can put it into a vise or clamp. This tool is the main crankshaft pulley washer! It's hard to get, yes. If you choose to improvise, either get a spare washer from a junked 944, or find some way of making the vise or clamp put its pressure on the outer edge of the tensioner body... not the stepped-up center.
Follow the belt changing procedures to help you put the timing belt back on, and put the BS belt back on (and aligned correctly for TDC). Don't forget to put fresh grease on the pivot post for the belt tensioner lever.
Don't forget to use all of the new parts, and put the fuel pump fuse back in.
- re-time the cams
- 8mm cheesehead (triple square) tool (I recommend buying a high-end tool to prevent stripped bolts and wasted time/effort).
- 10mm cheesehead (triple square) tool
- 27mm offset wrench (you can get away with a plain 27mm wrench)
- large vice, or C-clamp
- three M5x15 bolts
- 9248 Cam Saddles
- 9530 Assembly tools for Variocam tensioner and timing belt tensioner
- 9206/1 Flywheel lock (highly recommended)
Thanks to Raj for all his invaluable help putting this together. It was very much a team effort.
This will be updated with better pictures, and/or improvements to the procedure if/when the need arises.
Arash spent countless hrs and went thru a bunch of revisions, so a big THANK YOU to Arash
I will be doing this to my cab in the next few weeks so we will have some updates.
Raj
Raj
Fantastic write up guys. I sure wish you had printed this 2 weeks ago when I did mine. But thanks to Raj everything worked out. BTW, when removing the timing belt tensioner, I used a rachet on the tensioning arm toothed roller nut and pulled towards the left. It moved just enough to remove the hydraulic tensioner when fully extended. And believe it or not it slides right back in when assembling with not having to compress the tensioner. Hope this makes sense!
Kevin
Kevin
You all are very welcome. I hope it helps some people. It was a bear to make but I didn't do it all by myself . The information came from most of you people on here that have posted and discussed over time. By the people, for the people, as they say.
And there's lots of places in there where you might have a better way of doing things. Please do so, and maybe post it here too. There's more than one way to gut a cat.
Arash and Raj,
I nominate your thread as the "968 Post of the Year!" It's this kind of article that will keep the 968s on the road for a looooooog time.
Thanks for taking the extra effort to do this.
Harvey
Harvey
Harvey, thank you!
Kevin, that totally makes sense. And that sounds like a very nice trick - I'll have to try it next time. It would simplify the procedure for sure. Thanks for sharing!
Sweet write-up!
Is there a recommended interval for doing this service? Or is the need for this something that you only notice during, say, a timing belt replacement?
I would do it every 60K. It is inexpensive to do it yourself. The parts cost under $100 all together. You could make this as part of your timing/bs belt interval but most people prefer 45K interval, not 60K interval on belts.
Raj
Raj
I'm trying to decide whether to tackle this or have my indy do it. How long should it take? lets assume I'm capable and I'll multiply it by the appropriate incompetant factor. How long?
