View Poll Results: Molding or No molding?
Voters: 24. You may not vote on this poll
Side moldings or not?
I guess it depends on how you use the car. If you are going to park in spots where you run the risk of getting hit I would say yes. If it is a extra vehicle and you can drive it and park it accordingly then no.
Ok, Darryl what did you have to do to remove the strips?
Are they glued on?
Are they screwed on?
Most of the 968s for sale near me have that dang molding I want to know that if I remove the strips it won't make the car look worse.
Easy removal, they are glued on. You'll need to heat them up and use a special soft tool but they'll come off, then some adhesive remover and you'll never know they were there. They are cheap to buy new so maybe you can sell them and make a few bucks.
Jeff, if anything they are quite expensive. I thought a set of moldings was well over $500 for all 4 pieces.
I guess typical Porsche cost cutting. Most 944 turbo 's in the later yrs had them but most 968's don't have them.
Raj
Raj
