964 Forum 1989-1994
Fuel Lines
Old Dec 20, 2015 | 03:52 AM
964dxb's Avatar
964dxb
Default Fuel Lines
I read that its good to change fuel lines on a 964 if they have never been changed. Just bought a 964 (1990 C2) a few months back and was wondering if anyone had any views on this?
Old Dec 20, 2015 | 06:36 AM
Navaros911's Avatar
Navaros911
Timely post... I was thinking of preventatively replacing all fuel lines... And was wondering if anybody has a definitive list of all.
If not, then it's time to use the advanced search function.
Old Dec 20, 2015 | 06:53 AM
power_up's Avatar
power_up
Hope that help.
https://rennlist.com/forums/964-foru...l#post10579187
Old Dec 20, 2015 | 08:05 AM
Vandit's Avatar
Vandit
See my reply here.
https://rennlist.com/forums/964-foru...aced-them.html
Old Dec 20, 2015 | 08:26 AM
Duck's Avatar
Duck
I have replaced all mine in the engine compartment as part of my rebuild. Not hard to do with engine out.
Old Dec 20, 2015 | 11:12 AM
Goughary's Avatar
Goughary
Definitely replace your fuel lines.
The original lines were not made for use w ethanol. That's part of the reason that the car is only approved for a max 2% ethanol blend.
Old lines corrode and clog your fuel filter. That's one issue. Second issue is with up to 12% ethanol in your gas today, being very corrosive and on top of that running through old lines, it's a disaster waiting to happen.
Old Dec 20, 2015 | 11:38 AM
Duck's Avatar
Duck
The difficult ones would be ones back to the fuel pump.
Old Dec 21, 2015 | 09:10 PM
JJ964's Avatar
JJ964
If they're not leaking, leave them alone. They are made from Cohline heat formed semi rigid NYLON tubing with a rubber covering. They will not deteriorate like rubber hose from ethanol.
