My 964 C2 Transformation Build Thread
#361
GT3 player par excellence
"...I'm just ordering a few final parts for..."
SpyerX clearly have trouble understanding the words in bold
#362
Is he for hire? I'm sure he'd like to hang out in LA for a few days :-)
Today ordered what I hope is the last of the parts I need outside a few minor bits. Have a big pile ready to go when car goes to shop. Ordered a secondary oil cooler, new rear lens/lights and gaskets, new light bulbs all around, new belts for the rothsport pulley kit I'm installing, a few misc parts, and a wing. Going to give the narrow rsr Getty wing a go. Maybe I keep it maybe I keep it wingless. Not sure until I try it.
Either way, whatever you decide to do, with your attention to detail, i'm sure that the car will look lovely.
#364
I'm sure you're a better driver than I am and pushing the car more than I do, but I'm a little surprised you're seeing these temps after only 15 minutes at 70 degrees F? Perhaps it's due to the lack of a very long straight at this track? What oil/wt are you using?
#366
Your heat must be hot. I would run my C2 for an hour straight 4 back to back sessions all day at the Glen with both my wife and I driving. No doubt I push the car much harder but my temp gage never was above normal even when it was in August above 90 degrees.
Are you sure your fan or thermostat sending the oil to the cooler working properly? Sometimes the thermostat below the oil tank will clog up and needs to be rebuilt.
#367
I paid one of my lawn guys $200 cash to scrape all the glue out. Best money I have ever spent.
RE: oil coolers - have had 2 for many years and temps were helped by doing something that should have been obvious to me and also to the shop that installed - make sure all the holes around the cooler and everywhere are 100% closed/sealed so the air is forced through the cooler. It makes a difference - and chances are there are a few holes that need to be sealed.
That said I still may see 240 on a very hot day - like a 45 min sprint at VIR - but that that is rare.
#368
It was closer to 80 during the day and the shorter nature of the track I was wrapping out 2nd gear a lot.
We'll see how this works and maybe I turn that soon to be non-functional rear wiper switch into a manual fan switch for the fans :-)
I won't be running this car a lot on the track, but it does get hot here in the desert during the summer and i HATE HEAT ISSUES. My Gt3 just runs, and runs, and runs. BMW buddies... 2 laps, done. 2 laps, done..... hate that.
#369
I run w/ the stock brakes w/ no cooling and very rarely get a soft pedal - but do occasionally and (proper) cooling has been on the list for for many moons. I ran big brakes in 2012 (only) had 0.00 fade w/ the big brakes so yes I would direct as much to the coolers as possible esp if keeping a/c.
I use pfc fluid fwiw but also really liked Endless as well.
#370
#371
I'm thinking we will use the kit I got for the ducts to feed to the coolers.
Sunday Sunday Sunday.... TRACK DAY!!!! I'm going out again this weekend.
I'm going to put some brembo stickers and brake paint on my rotors and check temps. I'm going to guess they are barely operating in the optimal temp range.
That will give me some data to decide if I need the cooling or I use those ducts for the oil coolers.
#372
Maybe.
#373
Gassed up!
Brought car to joey today, pulled wheels off, flattened oil line a hair, did a little bit of clearancing on from liners... All looks good.
#374
^ red never looked so good before.
