964 Forum 1989-1994
Engine longevity
Old Sep 16, 2015 | 11:42 AM
placer's Avatar
placer
Default Engine longevity
I am looking at 964s, and I have noticed by reading through various threads here that many of these engines have been rebuilt/replaced at around 100k miles. Is this normal? My '89 Carrera had 170k on the original motor with no issues. Thanks.
Old Sep 16, 2015 | 11:47 AM
HalV's Avatar
HalV
My '93 has 154k and still shows much less than 5% leakdown on all cylinders. I think many of these engines get rebuilt before needed due to oil leaks.
Old Sep 16, 2015 | 11:50 AM
tdiquattro's Avatar
tdiquattro
200k miles, no smoke, no issues, solid power, I agree for many it is the oil leaks.
Old Sep 16, 2015 | 11:52 AM
Earlydays's Avatar
Earlydays
It is typically "oil leak panic" that drives rebuilds. The engines are very strong and have great longevity!
Old Sep 16, 2015 | 12:21 PM
ilko's Avatar
ilko
Agent Orange
My 964's engine was rebuilt at 164K miles. My 993 has 113K miles and is strong!
Old Sep 16, 2015 | 12:33 PM
Goughary's Avatar
Goughary
Most haven't been rebuilt. Many on the forum, have had top end rebuilds, and some have had full rebuild down to the crank.
Most didn't need it. Some needed it, and some wouldn't run without it.
You've got a few things at play. Your average 911 owner isn't on rennlist. That's first. So you don't hear from the happy guy at home who just smirks when he sees the inevitable oil on the garage floor and drives away...he's not a forum guy, and most aren't.
Forum people tend to be two types. Fixers and modders. Both are way more likely to open the motor to fix something that doesn't really "need" to be fixed. Fixers will fix something that's broken or go after marginable hp gains. Modders will fix things that aren't broken, make things look cooler, and go after massive hp gains where they rarely get much at all, but have gone down a slippery slope getting there...if you hang with either group, you will begin to believe that much work is to be done, when really, in most cases, it would have been ok to let it go and drive the car...
I'll give an example. I bought my car w 58k on it. Engine tray was on. Traffic, and subsequent burnt valves, crap caked all over everything. Oil dripping from everywhere it could find a place to drip from. Car ran fine. Cold, it had zero compression. But there was a strange noise. A tick I didn't like. Felt slow. Wasn't perfect.
I spent 20k doing a top end rebuild. Slippery slope, replaced everything. Car since, runs fine. Feels slow (because it is), and no longer drips. Did I need the rebuild? Thought I did. Maybe I did. Glad I did. But it ran. And it isn't faster.
Cold, zero compression. Hot, had compression, just not perfect. I likely gained a few hp doing the top end build, but on the street, not being timed, you just aren't going to notice (in real terms).
Well maintained, these cars will literally go forever. Lack of maintenance, and they will need maintenance. No big deal.
If I were looking to buy one, however, since so many of us have rebuilt the motors, I'd be looking for a car with a good rebuild. More because most of the people driving up the prices don't really understand what they are looking at, and will pay a huge premium for lower miles, and a higher miles car with better maintenance will go cheaper and would usually be a better car, because it's owners made it that way.
Old Sep 16, 2015 | 01:15 PM
Earlydays's Avatar
Earlydays
....also the 964/993 uses the "Metzger" engine and it is used as the base for the 996/997 Turbo's and GT3's, including the racing versions of the GT3. It is one stout motor!
Old Sep 16, 2015 | 02:22 PM
Tmistry's Avatar
Tmistry
I had no idea the 964/993 was considered a metzger engine. Where can I get more info on this? Any recommendation?
Old Sep 16, 2015 | 02:32 PM
Andy Roe's Avatar
Andy Roe
I believe that the GT3 block actually has a 964 part number?! Some info here:
https://en.wikipedia.org/wiki/Porsche_911_GT3
Agree that the 964 engine issues are way over blown and most do seem to be rebuilt due to leaks than actual wear or failures.
Old Sep 16, 2015 | 03:24 PM
jeanhules's Avatar
jeanhules
I'm at 181K with a rebuild at 100K. I plan on doing another rebuild at around 250K-300K which won't be for a while. Car is running great, just have to stay ahead of any problems with maintenance.
Old Sep 16, 2015 | 04:25 PM
Goughary's Avatar
Goughary
The reason the gt3 and the turbo don't have the ims issues, is because they are based on our motor...tidbit...
Old Sep 17, 2015 | 02:25 AM
Mixter's Avatar
Mixter
Default Why so many rebuilds
Here's a tread I started a while back. Received some good feedback that may help answer questions on engine longevity.
https://rennlist.com/forums/964-foru...-rebuilds.html
Old Sep 17, 2015 | 10:39 AM
Mondrian's Avatar
Mondrian
Carrera 3.2 engine is generally considered to be the most reliable of the aircooled engines so normal for others to fall short on mileage. 100k is about right for a 964 topend rebuild, some even earlier and a few have gone way past the 100k mark. Early cars (pre 91) would probably have had a reseal way before the 100k mark.
Old Sep 18, 2015 | 03:28 PM
Flat6 Innovations's Avatar
Flat6 Innovations
Former Vendor
Most of the engines I build for the 964 and 993 are usually from serious oil leaks that require tear down to completely adress. Seldom do we see failures of the engines, most all are elective builds, and some are just becaiuse someone wants more power.
Old Sep 18, 2015 | 04:38 PM
davidwilson11's Avatar
davidwilson11
That's the best explanation I've heard that describes me. It didn't really need done but you know what in my mind it did..... Love the cars, love fixing and improving anything I can. Well said dude.
