The silly little question thread ...
#1411
Burgled
I know i have seen it a hundred times but when I need it cant find it! What is the pattern for putting the nuts back on the valve covers? Thought it was in Adrians book but either over looked it or it isnt there! If it is does anybody have a page number :-)
#1412
Burgled
Hi, I ask here since I am 101% sure that this has been discussed already 2 million times but I am dumb enough not to find the right keywords to retrieve the thread.
Is it possible to operate the cabrio soft top with the engine on?
I understand that the factory solution is engine off and key turned, but I was wondering if there was some workaround to change it.
Thanks!
Thanks!
#1415
Burgled
It has to be wired different. I can open and close mine while moving up to about 10 MPH as long as the brake is pulled up atleast 1 or 2 clicks.
#1416
#1419
I will probably order a couple to see if they work, but for now, still looking.
#1420
Hi guys,
Any tips for attaching the gasket to the rear light of the 964 (full version of the gasket for <1991 cars). Im trying not to resorting to glue, but it keeps falling off under tension!
Chris
Chris
#1421
IHI KING!
I have those on my 1990 car. They are very fiddly to install but once you get it installed, the tail light will hold it in position. I don't use any glue on mine. My trick is to install it on the lens, then start connecting it to the car and use my fingers and a Popsicle stick to push the rubber into place.
#1422
chris
#1423
These studs for attaching the oil filter housing in the background? - don't remeber seeing these when I stripped mine down. Where or what part of the car did you find/remove them?
#1424
They thread into the filter housing in the background and that spacer in the fastener holds it so the grommets can go over it and between it and the bodywork.....as I remember.
#1425
If the studs are damaged and not usable then it's not impossible to machine new ones - just need to be accurate with the spacer gap value.
