The silly little question thread ...
#1381
do people who have fitted breather catch cans for removing the oil feed back tot he intake use the orig sized pipes?
They seem to be very large for a breather and most breathers I've found use narrower pipes.
#1382
#1383
Only other thing is do you have an aftermarket alarm fitted? With doors or front/rear lids open this will certainly draw current - I've had this issue in the past.
#1385
#1386
The air-cooled engine was developed by the Germans to cope with the harsh winters! As long as you have a properly tuned engine and a strong battery, there won't be a problem.
#1387
#1388
The engine deck lid light is housed in a small rectangular clear plastic cover flushed in the mid-section or center area underneath the deck lid. When the engine deck lid light switch is engaged (i.e. lid open, on position), the frunk light located on the passenger side (U.S. vehicle) underneath the hood will also be turned on. This is regardless of whether the hood is open or not.
So if you simply remove the light in the frunk while your rear deck is open, you should not have any further current drain. Hope this helps to address your issue.
#1390
Little black cover on bumper next to the fog light fell off during drive after a wash and I lost it. What is it?? Where can I get new one(s) and how do I keep it on. 50% / 50% chance I can get the pic to load.......
#1391
https://rennlist.com/forums/964-foru...elete-diy.html
#1393
IHI KING!
I glued mine on with 3M weatherstrip adhesive. Its held for over a decade.
#1395
https://rennlist.com/forums/993-foru...turbo-kit.html
