The silly little question thread ...
#1337
On my drive across the state from Spokane to Seattle and back this week I was suffering because of the heat! I've done the RS heater bypass and I'm telling you I still get tons of heat into the car. Even when I don't want it!
So, my question: Is there a fresh air intake somewhere or a setting for the CCU to do this?
It was raining cats and dogs and I had to have the window open a crack and the sunroof open a bit otherwise my eye ***** were drying out from the heat.
Thanks!
Thanks!
#1338
Thanks!
Thanks!
#1339
On my drive across the state from Spokane to Seattle and back this week I was suffering because of the heat! I've done the RS heater bypass and I'm telling you I still get tons of heat into the car. Even when I don't want it! So, my question: Is there a fresh air intake somewhere or a setting for the CCU to do this? It was raining cats and dogs and I had to have the window open a crack and the sunroof open a bit otherwise my eye ***** were drying out from the heat. Thanks!
#1340
Thanks, and will do. Looks like I'll be learning about the HVAC system of the car next. First it was the ignition system....LOL.
#1341
Hi guys
A little knowledge needed please...
i've just got this s/h (quite old but in good condition) Sports cat from a friend and I can't find anything online about it. I believe it was in a race 964.
He said he's not sure whether it's 100 or 200 cell?, all this is little beyond me but it's now fitted and with my cup pipe I think it sounds great.
Anyone recognise this brand or know anything from the details engraved?? It says Part No. KAT C2 and I think 18/04 or 18704
Your help / info would be appreciated... Thanks!
Mike
Mike
#1342
The air filter housing has four clamps. The front two are easy to close, especially as one end is attached to the box. The rear two long clamps don't appear to be attached and are difficult to fit. Is there a trick to getting these in place and closed?
#1343
Anyone know if this is fixable?
Plastic tip thing went missing, and it never really worked very well with the oddly-sized 964 cigarette lighter. Anyone 1) Know if I can fix and 2) if there's a better solution to getting this thing to stick properly in the lighter? The OEM pump connector is oversized and fits better than a glove on OJ's hand.
#1345
Originally Posted by LM964
Practice and a lot of feel and fiddling. I can sometimes understand the benefit of swapping to a cone filter that many do - more space and access.
#1347
which clutch kit do you guys like? pelican (OEM sachs?), OPC or ...?
thanks for that Steve W - the RS clutch makes the most sense for me
#1350
Engine Drop technicals:
why does the manual call for the Accelerator cable to be detached at the pedal when it seems much simpler to do so at the engine?
Any insights appreciated!
