964 Forum 1989-1994
The silly little question thread ...
Old 02-24-2015, 06:38 PM
  #271
Mr.Alex
Mr.Alex's Avatar
Would it be ok to use a 3/8 drive 22mm O2 socket to remove the nut on my HD's and then use it to reattach and hand tighten, and afterwards set to spec with my 1/2 drive torque wrench?
Meaning that hand tightening with the 3/8 drive will be enough to that the shock won't spin in place when I use just a regular socket on the 1/2 drive torque wrench.
Old 02-24-2015, 07:10 PM
  #272
John McM
John McM's Avatar
Originally Posted by Mr.Alex
Would it be ok to use a 3/8 drive 22mm O2 socket to remove the nut on my HD's and then use it to reattach and hand tighten, and afterwards set to spec with my 1/2 drive torque wrench? Meaning that hand tightening with the 3/8 drive will be enough to that the shock won't spin in place when I use just a regular socket on the 1/2 drive torque wrench.
I had to refurbish two shocks because someone used vice grips to hold the shock bodies. When it came time to refit I had a shop do the spring change. I just fitted the assembly. Easy.
Old 02-24-2015, 08:58 PM
  #273
Rocket Rob
IHI KING!
Rocket Rob's Avatar
Yes that should work fine. The size of the socket drive doesn't matter as long as you use the correct torque at the end.
Old 02-26-2015, 01:50 AM
  #274
HiWind
HiWind's Avatar
here's a silly little answer to the question ..
"How many countries are shown as point of origin on chips inside the 964 Motronic Ecu (for those PCA pub nights )
.... 4: Phillipines, Ireland, Portugal, Taiwan
(Intel, Phillips & Bosch also there but not with country name)
.. and yes Motronic is removed, checked, stock chip etc.. and only opened now for first time
for sale with OEM plugs for loom (ie removed from loom remaining in car) ... please pm for pics etc..
Old 03-01-2015, 11:36 PM
  #275
StopLookGo
StopLookGo's Avatar
While swapping out my front wheels (with the AP design/Design 500 wheels which rub like crazy) I noticed that the struts has threads on them. Does this mean they are height adjustable? 92 C2 by the way.
Old 03-02-2015, 09:10 AM
  #276
Rocket Rob
IHI KING!
Rocket Rob's Avatar
Yes, your struts are height adjustable. All 964s have them. Note that you cannot lower the car much with them, they are mainly useful for fine tuning. Any major changes in ride height should be done by lowering springs.
Old 03-02-2015, 05:56 PM
  #277
Mr.Alex
Mr.Alex's Avatar
I actually found a half open half drive socket on ebay so that will take care of things.
I don't suppose there is an awesome 2015 solution to dropping rear control arm without jacking the engine (on new-ish mounts) or taking the heat exchangers off?
Old 03-03-2015, 09:17 AM
  #278
Rocket Rob
IHI KING!
Rocket Rob's Avatar
Why do you need to remove the rear control arm? Not sure why you would need need to remove the heat exchangers off.
Old 03-03-2015, 09:42 AM
  #279
cobalt
cobalt's Avatar
Received 1,966 Likes on 1,188 Posts
You can remove the rear trailing arm without needing to remove anything more than the tire. There are three mounting points all are accessible however if they have not been removed getting the outer bolt loose could be a bit of work.
Old 03-03-2015, 04:20 PM
  #280
Mr.Alex
Mr.Alex's Avatar
Perhaps I messed up the name after reading a bunch of threads. I'm swapping the springs on my HD's and in order to remove the rear shocks the DIY's I've seen say the rear 'control arm' needs to be dropped to give enough leverage to get the shock out. The problem seems to lie in the bolt that adjusts the toe gets bumped against the heat exchangers.
Or is this only a problem for the OEM shocks? I doubt I have aftermarket end links on the rear to make this easier.
Old 03-03-2015, 04:33 PM
  #281
Rocket Rob
IHI KING!
Rocket Rob's Avatar
Mr.Alex - No need to remove the control arm to change the shocks/springs. You will want to raise the rear up to give more room to work. The shocks are attached to the lower control arm by a single bolt. That bolt tends to be stubborn to remove. The best way I found is a long cheater pipe on a breaker bar. The higher the car, the easier it is. I did it all with mine on jack stands. A lift is not required. The top bolts are standard 8mm (13mm nuts). They are a bit challenging to reach when the engine is installed but it can be done if you remove the rear heater blower and air filter box.
Old 03-03-2015, 06:03 PM
  #282
Rennbahn
Rennbahn's Avatar
So I have the dreaded "Xmas Tree" effect but only with the headlights on. I did a lot of searching reading about this problem and one of the recommended tests is to mist water around the dizzys and coils and look for sparking in the dark. Am I not supposed to see any sparks at all?
Old 03-03-2015, 06:23 PM
  #283
HalV
HalV's Avatar
^+964...no need to remove the control arm to change shocks/springs. I used a high torque impact wrench to remove the stubborn bolt on one side. The other side required a lot of persuasion with the pipe/cheater bar/jack combo. I also used a liberal amount of thread penetrant. Good luck.
Old 03-03-2015, 10:43 PM
  #284
Mr.Alex
Mr.Alex's Avatar
Wow this is great to hear, a bunch of past threads on here had opposite opinions. And I was just trying to follow DIY; steps 4-6 mention what I was referring too.
http://p-car.com/diy/sus/rear/rearsus.htm
Thanks guys, bought some PB blaster just in case.
Old 03-04-2015, 01:04 AM
  #285
Goughary
Goughary's Avatar
Alex. Hit them with pb blaster first and reapply a few times. Let that stuff seep in for a few days if you are concerned that the bolts have been on too long...it'll make them more likely to crack loose.
Quick Reply: The silly little question thread ...
