964 Forum 1989-1994
The silly little question thread ...
Old Mar 12, 2015 | 10:13 AM
  #301
cobalt's Avatar
cobalt
Originally Posted by Mr.Alex
I got those little pichers, but it would seem the rubber line is too stiff for them to constrict the line. It would seem as it if barely compresses it.
Might be time to consider new brake lines. Depending on the cars history will determine but if they are original it may be worth consideration. A lot of us should start considering inspection and replacement of our brake, clutch, oil and fuel lines.
Sounds like a job you should set aside a lot of time for. If the lines have not been opened you may find everything will take 3-4 times longer than you expect especially if this is your first time. You may consider a radiator hose clamp but use with caution. http://www.harborfreight.com/radiato...ers-99704.html
Old Mar 12, 2015 | 05:29 PM
  #302
Mr.Alex's Avatar
Mr.Alex
I got everything off, the strut off the hub and all nuts, but the top mount seems adhered to the body. I got the side closer to me loose but cant get the other side loose. I'm trying not to shimmy it too much so i dont break the studs up top. Any tips?
Old Mar 12, 2015 | 05:41 PM
  #303
John McM's Avatar
John McM
You mean the very top? It should have a rubber gasket that may be sticking. I think I left the bottom nut connected and pushed down on the wheel hub to loosen the top
BTW there is a DIY on the net for changing Bilsteins. I don't have the link on my iPhone.
File Type: jpg
Old Mar 12, 2015 | 05:42 PM
  #304
cobalt's Avatar
cobalt
Never mind John beat me to it.
Old Mar 12, 2015 | 05:49 PM
  #305
John McM's Avatar
John McM
The quick and the dead Anthony!
All this talk of suspension is reminding me that the hardest period of my Turbo 3.6 (car I put new Bilsteins on) sale is about to occur.
The car has arrived in England and is about to be registered with a new plate and titivation.
I imagine a lot of posts will ensue. Can't have the cake and the money...
Old Mar 12, 2015 | 06:45 PM
  #306
cobalt's Avatar
cobalt
All the best, it can't be easy but you have been down that road before and you did the right thing the first time I wouldn't second guess myself.
Now if I didn't have the opportunity to step into a GT4 order I might have been able to keep my sanity but something has to go.
Old Mar 12, 2015 | 06:58 PM
  #307
John McM's Avatar
John McM
All the best, it can't be easy but you have been down that road before and you did the right thing the first time I wouldn't second guess myself. Now if I didn't have the opportunity to step into a GT4 order I might have been able to keep my sanity but something has to go.
I'm in lust with my R, which is actually bigger than my 964. The GT4 is a couple of grades above the R. You are a very fortunate man.
File Type: jpg
Old Mar 12, 2015 | 08:14 PM
  #308
Goughary's Avatar
Goughary
Awesome that you are doing all this Alex...
I'm starting C9O (connecticut 964 owners)...feel free to come up for the meets and drives. We will likely do it around the c and c schedule since there will be so many guys from the further reaches of the area in town. We will also likely do maintenance/tech days in places like...my garage...and anywhere else any member wants to do it...regardless, the point is, feel free to join in...all are welcome.
Old Mar 12, 2015 | 08:31 PM
  #309
Mr.Alex's Avatar
Mr.Alex
I'm assuming its the gasket, because with everything loose there is nothing else holding it. BUT, I used a variety of pry bars and as much pressure as I could apply without putting the studs in danger, but no go. I only got the once side loose, I can't seem to figure out a way to get the other side loose. I tried using a rubber mallet to knock some sense from the top in the trunk but no go.
So I put the strut back on the the wheel carrier and called it a day for now, thinking if anyone ever had same issue on here.
This is how I left it at the moment/
Awesome, seems like its spreading quite a lot. I'm just disappointed in how much time its taking me so far with the weather getting better. I'm still waiting on the updates gear box bushings to drill for the short shifter, and now that I'm here I'l probably end up doing the ECS brake lines also.
Old Mar 12, 2015 | 10:28 PM
  #310
Goughary's Avatar
Goughary
Cool. Do a diy write up on the brake lines. I have never even had my calipers off...so to see the process before doing it would be great. I think I may be rebuilding my calipers in the coming months, so will likely do brake lines while in there.
Old Mar 13, 2015 | 09:28 AM
  #311
cobalt's Avatar
cobalt
Try a heat gun or hair drier. Also leave the outer or loose bolts in place but not tightened and start to pull it out towards you, eventually it will give. If that doesn't work replace the nuts onto the two studs that won't give so they are flush with the top of the stud. Using a comfortable but heavy (2-5 pound) mallet tap the top of the stud it will give way eventually the nut will protect the threads and top of the stud. Don't waste your time using a light tap hammer you need the force to break it free. I'm also a huge advocate for giving the entire wheel well a good cleaning before installing the new struts. Use a citrus degresser and some nylon brushes to work the road grime free, I usually remove the wheel liners and clean everything you will appreciate it in years to come.
It takes a lot of patience to attack these jobs the first time. Am I correct in saying you already have bilsteins on the car with factory springs?
John your making it difficult to say no. The car is white over black as well. After having the boxster I can only imagine what they are capable of. The R is one worth holding onto as well.
Old Mar 13, 2015 | 09:41 AM
  #312
John McM's Avatar
John McM
It's great having a near new Porsche to complement the old ones. The R is a great drive. The GT4 would be epic and probably cost you nothing in depreciation for a year or two considering the demand.
File Type: jpg
File Type: jpg
Old Mar 14, 2015 | 01:36 PM
  #313
Rennbahn's Avatar
Rennbahn
Default Christmas Tree Effect
Originally Posted by Rennbahn
So I have the dreaded "Xmas Tree" effect but only with the headlights on. I did a lot of searching reading about this problem and one of the recommended tests is to mist water around the dizzys and coils and look for sparking in the dark. Am I not supposed to see any sparks at all?
The misting of the wires is to check for leaks in the wires and connectors. When I had the Xmas tree, it was simply bad coils, but misting wouldn't have shown me that.
Good luck tracking it down. I would try a new set of coils first, since it seems to be the usual suspect, but careful to not jus throw money at it. It gets expensive. Some free things to try are to take off all the grounds on the main wiring looms, clean and reinstall them. There are quite a few around the car. Take off each plug wire and connect a multimeter to each end and check to see each one reads at or very close to 3ohm.
Then inspect the wiring looms that you can access and check for cracked wires and shorts.
And since it's happening when your lights turn on, pop out the lights and check the wiring to the bulbs and trace back as best you can. I'm sure there are a few other free things to look into, but can't think of them off the top of my head.
In the end, when all else fails, after you have exhausted the easy stuff, pull out the clock and send it off to be resoldered...or if you have the expertise, check the soldered connections in there as well.
Great news!! Replacing the coils did the trick, two days and no Xmas Tree Effect! A big thanks to Goughary and this forum for the info/advice!!
Old Mar 14, 2015 | 02:26 PM
  #314
John McM's Avatar
John McM
I'm assuming its the gasket, because with everything loose there is nothing else holding it. BUT, I used a variety of pry bars and as much pressure as I could apply without putting the studs in danger, but no go. I only got the once side loose, I can't seem to figure out a way to get the other side loose. I tried using a rubber mallet to knock some sense from the top in the trunk but no go. So I put the strut back on the the wheel carrier and called it a day for now, thinking if anyone ever had same issue on here. This is how I left it at the moment/ Awesome, seems like its spreading quite a lot. I'm just disappointed in how much time its taking me so far with the weather getting better. I'm still waiting on the updates gear box bushings to drill for the short shifter, and now that I'm here I'l probably end up doing the ECS brake lines also.
This is DIY page I used for guidance http://p-car.com/diy/sus/
Old Mar 14, 2015 | 04:30 PM
  #315
Goughary's Avatar
Goughary
Rock on. Glad that helped. Enjoy the spring...
