gear oil , one more time !
hi guys ,
I know most of you use Mobile Delvac, quite difficult to find in France,
I have been suggested this ,
it's for a C4
MOBILUBE 1 SHC 75W-90
http://xom.ee/files/62_glxxencvlmomo...shc_75w-90.pdf
anyone had experience with this oil...
thanks
it's for a C4
thanks
hi guys ,
it's for a C4
thanks
it's for a C4
thanks
SHC was the original name for Delvac, I thought the name change was worldwide but perhaps not, this is great oil for race trans but may not be best for a street trans.
I've used SHC in a different car and its was a little too slipery for the synchros when cold.
The synchros on the g64 can be a bit slow so instead I went with motul 300v gear oil when i change the gear oil in the c4 which has been fine just a little baulky when dead cold. Next time I'll go with something a bit less modern, a mid level semi synthetic would probably more in line with the gearbox design and age.
As I understand it SHC is as close to devlac as you can get in europe. Very high spec stuff and would be fine, just maybe not 100% suited to the application for street use as Bill says.
I have been running Amsoil SVG 75w110 in the 964 cup...It has never shifted better...I realize that is no indication of gearbox protection but it sure does feel good. I will do a UOA at the end of this season and start comparing trends after a few more years of use with this gear oil.
On fitting an LSD I used Castrol Syntrax 75w 140 as recommended by my Indy. It is night and day better than before. Well recommended if you can get your hands on it.
By all means try olive oil but I suggest you make it extra virgin. Let us know how you get on
