Particularly UK peeps as I guess we'd all have retrofits if at all?
I've currently got the hoop / aerofoil / bridge / whatever you want to call it spoiler that sits just over the top of the engine lid. i.e. this one. But I don't like it. Ruins the lines IMHO and looks like a buggy handle.
So thinking about the 993 rear window spoiler, i.e. this one.
But not sure I can be bothered with the fitting. And again whether they clutter the rear up?
Which I guess then means an internal one. But what to go for without it looking like a Halfords special?
Or perhaps none at all? We don't have to have one in the UK do we? But I do want people behind to know I'm stopping.
Come on, show us yours...
I put on the 993 looking one. I believe it looks very good, and improves rear visibility. However, the black rectangle on the glass remains, and as far as I know, nobody has been able to remove it.
Right, I've gone for the rear window 993 spoiler brake light; thanks to an ebay tip-off from freedman
Will probably be a while before I fit it because it needs spraying and taking off my old hoop spoiler will leave holes. So I'll probably tie in with when I get other bits of body work sorted / the whole car re-sprayed!
The idea being that it gives an extra level of prevention about being rear ended, is unobtrusive to the rear view and easily reversible. Anyone done this?
You can easily fit a $ 10 red LED strip to the window rubber.
You can fit the strip on the inside at the top (on the backside of the window rubber) and run the wire behind the rubber down to the connector which is under the rear parcel shelf.
30min work max
Reason: edit typo's
Cheers
Good work Scott, I saw Gary's post too, thought "that's a good price must place a bid", but never did... you snooze, you lose!!
Something I want to do though, improves the rear roof line I reckon + good to have that extra brake light when numpties are on the road.
I have one of the 993 type ready to be fitted what`s involved with the wiring do you need to drill a hole to drop the wire down and then run it to the rear lights or is there a connector behind rear shelf as mentioned ?
30min work max
Both sounds like good cheap simple solutions. I've just been worried about them looking like bodge jobs. I guess if you can get it to look fitted then job done. But it's a shame when you see cars with the stick on look, especially when they start coming unstuck.
I guess now I've bought the 993 spoiler, I'll press ahead with that. But it would be good to see if anyone does have a budget after market solution installed that looks good.
I'm glad I bagged it quickly then
Yeah, exactly. Modern drivers expect to see a 3rd brake light these days I think. I have got one already, as said in the opener, but it's the hoop spoiler, which I'm not keen on. I think they're better suited for cabs because they can't do anything on the window area.
I won't get around to doing mine for a while but I found these as part of my research; looks like they might help:
I asked my mechanic to rewire the rear foglights with the brake lights. Now, four lights lite up when I brake, with the rear foglights at least 50% brighter than the conventional brake lights.
