964 Forum 1989-1994
Tin worm removal !
Old 02-06-2015, 11:21 AM
  #166
Metal Guru
Metal Guru's Avatar
Originally Posted by springer3
If you are using a grinder, be aware that grinding puts strain energy into the metal grains, and it is energy that drives future corrosion - even under paint.
If that were true every panel on the car would be rusting as there's a lot more strain energy in stampings then in metal that was removed by grinding.
Old 02-06-2015, 04:31 PM
  #167
jimq
Burgled
jimq's Avatar
that fan need replacing. If it falls apart like some have on here and mine was very close to doing all your work may become a real mess.
Old 02-06-2015, 05:03 PM
  #168
GazC2
GazC2's Avatar
Jim,
Pretty sure the fans ok no sign of any hairline cracks or delaminating dont see any huge issue with the pitting once its powder coated should be tickety boo
Old 02-06-2015, 05:33 PM
  #169
R6XTERRA
R6XTERRA's Avatar
I think both colour schemes look great...its just which are you more in love with? Mine is done like the 2nd picture...black and red.
Old 02-11-2015, 05:40 PM
  #170
GazC2
GazC2's Avatar
Ok so got some of my bits back today, I really wanted to do the fan silver however because of the pitting ( I know Chief I should have spent hours prepping) we felt the finish would look a bit rough and stand out more on the silver so red it was,
Old 02-12-2015, 03:43 AM
  #171
BLACK-BETTY
BLACK-BETTY's Avatar
Looks great fella.
Old 03-11-2015, 06:50 PM
  #172
GazC2
GazC2's Avatar
Cheers Frank getting there slowly, gave the valve covers a bit of VHT red crackle and fitted new clips for the leads.
Problem uploading pictures tonight link here
http://911uk.com/viewtopic.php?p=1056478#1056478
Old 03-12-2015, 05:21 PM
  #173
GazC2
GazC2's Avatar
Default valve covers
Here we go
Old 03-12-2015, 05:22 PM
  #174
GazC2
GazC2's Avatar
Got the injectors back from cleaning today which was a very quick turnaround it would appear they were still in pretty good working order after 25 years although I have gained 32cc/min which must be good right
Old 03-12-2015, 10:22 PM
  #175
964Lovac
964Lovac's Avatar
those valve covers look top... Just paint, no primer right?
Old 03-13-2015, 06:10 AM
  #176
GazC2
GazC2's Avatar
No they got a layer of primer as well kit details here
http://www.ebay.co.uk/itm/281518893320?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 03-16-2015, 06:28 PM
  #177
GazC2
GazC2's Avatar
Grabbed a hour in the garage tonight got the oil pressure sender seal changed old one was ok if a little brittle and stuck the missing nuts on this time,stuck the injectors back in the housings and replaced the bottom seals again all ok but really brittle. Removed the regulator from the alternator had a bit of life left however will be changed for a new one.
Old 03-29-2015, 10:09 AM
  #178
GazC2
GazC2's Avatar
Hibernation almost over Very Happy waiting on new pads for the front arriving and Kev the car doctor is popping over midweek to do the valve clearances then button everything up happy days. Pics of engine bay to follow.
Old 04-02-2015, 06:05 PM
  #179
GazC2
GazC2's Avatar
Well got the old girl fired up tonight Very Happy the plan for the winter was to strip out the AFM,air intakes etc as there was signs of an overfill I also wanted to give it a general tidy up and once over so the while your in there turned into
Fan & Housing refurb powdercoat
Intakes Cleaned and powder coated
replace seal Oil Temp sensor and add nuts to hold it in !
Full service oil,valve adjustment,fuel filter
Fit carbon heater bypass & carry out wiring mod
Injectors ultrasonic clean & tested
Fit soundproofing bar to tidy edge up
Paint valve covers and fit new clips
Powdercoat one tinware replace other with new
fit engine bay labels
Sure I have missed some bits wanted to get some bits replated but never managed ( just cleaned up the alternator strap)
so took the DME out turned it over a few times got some oil pressure/fuel put the DME back in fired up first time
Very Happy
so started with this and ended up with below
Old 04-02-2015, 11:46 PM
  #180
R6XTERRA
R6XTERRA's Avatar
Awesome transformation....i will be installing my cabron fibre bypass this weekend as well.
Quick Reply: Tin worm removal !
