964 Forum 1989-1994
Yet another engine drop thread
Old Jul 11, 2012 | 06:36 PM
  #46
RicardoD's Avatar
RicardoD
I could not find the easy to understand DIY for removing the throttle cable at the engine. Because I would have loved to have down that.
Old Jul 11, 2012 | 06:42 PM
  #47
Makmov's Avatar
Makmov
Not supposed to take it off at that end.
Old Jul 11, 2012 | 06:46 PM
  #48
RicardoD's Avatar
RicardoD
Which end Makmov?
Old Jul 11, 2012 | 06:49 PM
  #49
Makmov's Avatar
Makmov
Not the engine end. Take off at the pedal end and then slide the cable out of the out sleeve.
Old Jul 11, 2012 | 08:46 PM
  #50
PChar's Avatar
PChar
And why not,...!
Old Jul 11, 2012 | 09:01 PM
  #51
Makmov's Avatar
Makmov
Porsche said so
Not sure you can without jacking with the cable tension and idle, or possibly damaging it.
Old Jul 11, 2012 | 09:39 PM
  #52
LouZ's Avatar
LouZ
From: Philly Area ----- George Washington took a dump in my backyard!
Stephane
I also dropped the engine multiple times this past winter. Each time I disconnected from the pedal.
Even after the engine sat on the ground, I had to undo a few areas on the back of the engine to get the cable off. It just doesn't hang free when you turn the barrel on the throttle linkage and release it. (Stephane, you likely know Myles) he says to do it from the engine also, BUT, just maybe, it's different on a Tip.
Old Jul 11, 2012 | 10:58 PM
  #53
Makmov's Avatar
Makmov
Originally Posted by LouZ
Stephane
There is no notations in the Porsche Factory Service Manual to do Tips any different than manuals.
Old May 19, 2013 | 09:57 PM
  #54
RicardoD's Avatar
RicardoD
About a year later the engine is back in. Again we used Adrian's book as a guide. Some pointers:
- install the flexible orange heater ducts on chassis side while engine is still out
- as you get about 2-4" away you can hook up starter & starter ground, ATF lines.
- go slow we almost pinched an oil line
- if you use 993 c4 mounts you need an extra deep 19mm socket for the engine mount bolts
With the ATV jack and my lift this was very straightforward
Once again thanks to rennlister Stevepaa for his help today
File Type: jpg
