A photo journal of my recently completed big project
#39
I just want to clarify that in some of the pictures where i'm working on the left side timing chain cover, tensioner, and crossover, I have the distributor caps removed. You do not need to remove the distributor and/or distributor caps to work on these areas. The only reason why I have the distributor caps removed is because I had also done the valve adjustment, so I removed the caps to find TDC and did not reinstall them prior to wrenching on the timing chain area.
#41
Per RicardoD's valve adjustment thread, the Z1 mark on the crank is TDC for cylinder #1 and cylinder #4. You need to align the marks on the distributor rotor to be sure you're on TDC for #1.
RicardoD's thread
https://rennlist.com/forums/964-foru...or-method.html
Specifically this post
https://rennlist.com/forums/9076077-post24.html
RicardoD's thread
#42
Super Duper Moderator
RicardoD's thread
RicardoD's thread
Marc
#43
Wow, Vandit, just catching up on this thread. It is a fantastic resource for me. I need to do all the work covered in this thread on my C2. It should hopefully be a bit easier as I just dropped the engine.
What's the secret to removing the crank pulley? I keep reading about a special tool. I don't want to screw that up.
#45
Lots of not-so-big expenses that add up when you hit that "=SUM" function on the "964 Receipts.xlsx" Excel workbook.
