964 Forum 1989-1994
Is it common for spoilers to crack here?
Old 04-09-2012, 08:39 PM
jody stowitts
jody stowitts's Avatar
911Jetta: I would guess that your crack is ACTUALLY 1-4mm more towards port than starboard. Hope you'll measure it very accurately and get back to all of us on this monumentally critical issue. Please hurry, as time is of the essence. CHEERS.
Old 04-09-2012, 09:01 PM
MrNvgtr
MrNvgtr's Avatar
Funny, I have the same crack in the rear too. I'm sure there's a good reason for it, but my care-factor is fairly low on this one.
Old 04-09-2012, 09:28 PM
Sultan
Sultan's Avatar
anatomy 101 should help you understand what cracks in the rear do!! LOL
I'm fortunate, no crack in my 964.
Old 04-09-2012, 09:32 PM
jody stowitts
Sultan: Cracks riding shotgun, the only way to fly!
Old 04-10-2012, 01:34 AM
stinkydog
stinkydog's Avatar
I've got 2 of them.
I contemplated spending some time with the plastic weld / filler and sandpaper, then touchup paint....
I decided to drive the car instead.
The permanent solution is, get a ducktail, scrap the spoiler motor and hardware, and save a couple pounds.
Old 04-10-2012, 09:02 AM
ScottR
ScottR's Avatar
Mine's cracked on the left side too as per the pic. I had no idea this was a common issue! Will look for some wear marks now as mojorizing suggests.
Old 04-10-2012, 12:45 PM
911Jetta
911Jetta's Avatar
Too close to call from here...will measure tonight.
Old 04-10-2012, 04:40 PM
CBR786
CBR786's Avatar
Mine has it too
Old 04-10-2012, 06:53 PM
c didy
c didy's Avatar
Some think it's because one side is closing too tightly.
" I suspect that the primary reason for most spoiler cracks is poor rigging of the spoiler position limit switches. If you extend the spoiler manually you will gain access to the limit switches and can then adjust them. They are on the left hand side were the drivegears for the spoiler are located. My down (stowed position) switch was out of position causing to much preload on the panel leading to the fracture. "
Old 04-11-2012, 01:30 AM
touque
touque's Avatar
Mine is exactly in the same place. Was going to try to repair the spot when I fixed my peeling clear cote on my wing but will definitely have to check the preload adjustment first. No sense in repairing the crack to have it come back right away.
Old 04-11-2012, 10:10 AM
D.C.
D.C.'s Avatar
Mine is cracked as well. It is not that noticable so I am leaving it alone.
Old 04-11-2012, 10:11 PM
chris951
chris951's Avatar
I have crack like that. My spoiler has never sat evenly when it is down. I'll leave it alone.
Old 04-12-2012, 12:37 AM
carlskisWP
carlskisWP's Avatar
My crack is on the right side. Tried epoxy and it didn't hold as I couldn't get the two sides clamped together tight enough. So I tried some gorilla glue, the stuff that expands, and it has held up so far (for a few months). At the same time I also "repaired" my torn spoiler wall with black duct tape. Maybe that will add some stability.
Old 04-13-2012, 05:01 PM
c didy
c didy's Avatar
So the answer to the original question is that yes, this is a common problem. It would be nice to know what the problem is. Spoiler wall, dying bearings, poor opening/closing symmetry?
If it's the spoiler wall how many people with cracks have defective or absent walls? How many know what a spoiler wall is?
Old 04-13-2012, 05:21 PM
Vandit
Vandit's Avatar
Spoil wall torn and a crack on the left side.
Quick Reply: Is it common for spoilers to crack here?
