Fuchs For 964...
#196
Paint the little spoiler above your rear window black too.
#197
When you have your Fuchs, you want the best tyre service fitting possible. I've just gone through my first set of track tyres so went to see how the tyres are taken off without touching the wheel. It may be normal in other markets but if not then seek out this type of machine
#199
On my 964 I have Fuchs with 993 calipers/RS uprights - fits just fine. See pic. There's enough radial clearance to clear big reds on 993 uprights. Clearance from spokes to caliper is very tight - about 5mm.
If you have big reds mounted on 964 uprights with mounting brackets - I'm not sure - you may need spacer, geometry is a bit different.
#201
#203
Info much appreciated
#204
rear wheel size
the 964 rsa was running 17x8 in back 17x7 in front. what the down side to running 17x9 in back I know it will fit but I question as to Porsche 17 inch wheel sizes from factory. thanks
#205
#206
Though that you all might like to see some detail photos of a front & rear 18" from a set of Fuchs that we have just bought in to fit on a customer's 964?
Enjoy!
Enjoy!
#210
Hi Colin,
They look really beautiful
I have a set of Veloce Speedlines on at the mo, 8J x 18 with 225/40ZR18 Contisport on the front and 9.5J x 18 265/35ZR18 Contisports on the rear. These clear the Turbo callipers on the front and 993 callipers on the rear and without the need spacers.
Do you know if I can use 18" Fuchs without spacers and clear the brakes please?
Also what finish is that please, it almost looks like RSR? I'd love to see a pic of them on the car.
Thanks in advance,
Paul
Thanks in advance,
Paul
