993 Steering wheel on a 964
I was jus saying that the 993 went on with no probes 996 was a pain. If you say 993 and 996 is the same sure it is. Got off the subject a bit because I have the three wheels, all been on the same car. But I Would not even know where to begine with clock springs to do a proper install..
https://rennlist.com/forums/964-foru...-on-964-a.html
https://rennlist.com/forums/964-foru...a-964-tip.html
https://rennlist.com/forums/964-foru...different.html
https://rennlist.com/forums/964-foru...ing-wheel.html
https://rennlist.com/forums/964-foru...-91-964-a.html
https://rennlist.com/forums/964-foru...n-a-964-a.html
https://rennlist.com/forums/964-foru...t-on-964t.html
https://rennlist.com/forums/964-foru...ng-wheels.html
Unless I find a cheap steering column and clock spring it appears I am better off (financially) going to a nonairbag aftermarket arrangement , If you have the column or clock spring for sale please contact me
Last edited by Silvertarga; 02-28-2011 at 06:12 PM. Reason: Wheel is on Column was NOT necessary
Cheers
Here is the end of the link...... But They did say the shaft is shorter, I was fine with out using the fat washer...
I did not have an airbag wheel and this is what I did ...
https://rennlist.com/forums/964-foru...erturismo.html
No. Just pick it up from its winter sleep over last week when it was 45sh tuesday, brought her back to the shop to install the goodies I got the past few months.. Have not driven it in about three months. It was nice!!!!! Were getting more snow UNCLE !!!!
Thanks to all of you for your help, I will now begin the search for a reasonably priced 993 clock spring and steering column (before I get rid of the 993 steering wheel)
Thats funny Back in 05 you guys(rennlisters) had a thread about a car that I built. It was on ebay at the time... 3.3 turbo roadster.. I had a 993 wheel with Tiptronic but had a six speed in the car.. People were liltle confused why I did that..The buttons CONTROLLED THE STEREO!!!...Like the way the guy above thinks!!!! Did not need a 993 shaft for that one either... Try that wheel before you buy a shaft... sterring colum..
